Old 8/19/08, 3:44 PM
Matthew J. Johnson's Avatar
Matthew J. Johnson Matthew J. Johnson is offline
Send a message via Yahoo to mjohnson6
Please Note: mjohnson6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Question What is a Point Well?
What is a point well.
What considerations should I be thinking of when inspecting one?
I'm assuming it's some type of water well, but im not 100%.
Open for "point well" taken discussion.
Old 8/19/08, 4:05 PM
Default Re: What is a Point Well?
At the risk of sounding arrogant and sarcastic, which although I am this is not intended to be...
If you don't fully understand it, don't inspect it till you do.
This is a start: http://hydrology1.nmsu.edu/hydrology/wellpoint.htm
Abraham Lincoln
Old 8/19/08, 4:06 PM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Are you speaking of a driven well that uses a sand point?
Shallow well less than 25 feet.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 8/19/08, 5:32 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
Mike,
Must be a well point. Used for driven wells, as you said. Can go deeper than 25 feet, depending on conditions. Uses a packer assembly to allow water from the pump down the pipe, where it changes direction n the assembly and heads up a 2nd route. A pipe within a pipe with nozzle and venturi in the packer. System uses a 2-pipe jet-pump.
Old 8/19/08, 5:34 PM
Thanks for the clarification Joe,
Michael Larson
Hudson, WI
Call me
Old 8/19/08, 10:11 PM
Jerry Bettencourt Jerry Bettencourt is offline
Please Note: jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Matthew, listen to Joe he knows his wells.
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 10:24 AM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 11:19 AM
