Old 8/9/12, 7:33 AM
Curtis Hildebrand Curtis Hildebrand is offline
Send a message via AIM to childebrand
Default As least they KNEW it was wrong
I inspected a house yesterday where both bathroom fans terminated into the attic plus there was a leak into the attic from the chimney. I guess the home owner realized there was an issue because he added a dryer termination cap to the end (I'm assuming to keep the cold out in winter) and lay down plastic to keep the insulation from getting soaked. You gotta give him points for creativity.
As least they KNEW it was wrong-img_7679-jpg   As least they KNEW it was wrong-img_7681-jpg
Kingdom Home Inspections
Old 8/9/12, 7:48 AM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: As least they KNEW it was wrong
I don't know if I can track the pictures down but more than a few times I have found them feeding into an upright paint bucket right under the turbine.
Best design now is out into the soffit with a proper vent hood, no messing with cutting holes in the roof.
Free Books And Articles For Electrical jtedesco1 Electrical Inspections 14 1/6/08 7:45 PM
What's Wrong Here? jtedesco1 Electrical Inspections 10 12/9/07 10:36 PM
