Henri here, an ashi member… Q— assessing a crack in foundation wall that leaks when it rains a lot, what TA do, what TA do? They say supposed PRO’s wanna slap crap on the inside including Drylok for around $700 loooolll
About the House: Assessing a crack in the foundation - Entertainment & Life - telegram.com - Worcester, MA
Henri’s reply in-part, hairline cracks can be IGNORED. Really? They just told you the crack LEAKS, whatever size, waterproof the crack man!!!
Then he adds, he thinks its a GRADING problem lool because it only leaks when they get a lot of rain, pfft, see video below, it ONLY leaked on heavy rains Henri! hahhaaa oh man!
Then he says if concrete patio slab slopes towards DUH house/wall then… THAT can be the problem. Wrong answer again, See OTHER video below
Hairline crack poured foundation wall, leaked on heavier rains…
https://www.youtube.com/watch?v=N0yy3ssCgA4)
Someone slapped on some tar… not enough, doesn’t last, not a good enough job baby! So Henri, IGNORE these hairline cracks that allow water in huh?
NEW DRIVEWAY poured, ummm slabs pitch awy from the stupid house!!
How much $$$ did THAT cost? Did it solve the problem? Nooooooo.
https://www.youtube.com/watch?v=su-FUMTaHIE)
See the deterioration going on??? What? Just allow it to get worse? Pour MORE concrete? hahahaaa
IN--------------------------------_____COMP-----___etent!!!
Waaaaaaaaaaaaaaaaaaaaaaaaaaaay too many try n kick—the----can down the road to the NEXT homeowner (when selling the stupid house), need to be sued for not disclosing EXISTING DEFECTS, tired of this shtt.
If there was a HOLE in the ROOF, an existing defect… (when selling the stupid house), would they plop a tarp over the hole and claim it is now fixed/repaired??? C’’’’'mon!
You have NOT fixed/repaired anything by raising and sloping the grade or extending downspouts 99 miles away or mudjacking slabs or pouring 22 miles of concrete AND, you have NOT identified the actual-existing problem(s). Doing this CRAP… you are only guessing and hoping, pfffffffffffffffffffffffffffffffffffffffffffffffffffft
Homeowner here already RAISED and SLOPED the stupid grade away, kept leaking, found n called my dirty azz… ran a water test and showed him that there are exterior openings in his block foundation wall because… when running the water/hose they got water in, on floor after a few minutes of running the water!! looollll GAS LINE and hairline vertical crack were the problems, NOT the lousy stupid GRADE!!!@!@@#%#https://www.youtube.com/watch?v=3dsL-RQeEOA)
The supposed pro’s who apparently wanna slap crap on the inside for around $700, aren’t pro’s!
