Old 2/11/18, 7:31 PM
Michael Rodney's Avatar
Michael Rodney Michael Rodney is offline
Default Column
Can anyone say for sure if this type of column is (or is not) intended for permanent use?
Column-20180208_172843-jpg   Column-20180208_172832-jpg
Michael Rodney, C.E.T., ME
Qualitex Home Inspection
Mississauga, ON.
Canada
416-997-3466
http://www.qualitexhomeinspection.ca
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/12/18, 2:33 PM
William B. Ogletree's Avatar
William B. Ogletree William B. Ogletree is online now
Default Re: Column
Saying "for sure" would require knowledge about what code requirements are for permanent steel pipe columns, the specs for the item pictured, and the load it is bearing. All of that would need to be addressed by a structural engineer before any definitive pronouncement could be made, and is beyond the scope of a standard home inspection.
William Bruce Ogletree
Ogletree Inspection Services
TREC License 22530
214-287-4630
www.ogletreehi.com
ogletreehi@gmail.com
Old 2/12/18, 8:09 PM
Default Re: Column
Thanks for the reply William. So if I see one of these in a home I make no comments in my report regarding it?
The reason I am asking about it is because this one is in a home where the original one was removed so they could add a door, then this one was used as the replacement about 2 to feet from where the original was. The inspector in his report (about 4 years ago) said it should be replaced.
Mississauga, ON.
Canada
416-997-3466
