Old 4/3/13, 1:02 PM
Larry King Larry King is offline
Default Foundation Cut and removed Why?
I have seen a-lot of firsts this week. Home built in 1978. Forclosed in 2012. Home has poured and concrete block foundation with basement and crawlspace configuration. Inspection of crawlspace area observed a trench dug along the wall of basement and a section of foundation cut out under front wall at garage slab. Foam board insulation was installed.
Any ideas why they would have cut foundation and removed such a large section? Seems like a-lot of work. Would it be for foam board installation? What would you recommend?
I have included photos and a "crude" drawing of area in question.
Let me know what you think.
Thanks
Foundation Cut and removed  Why?-cut-foundation-jpg   Foundation Cut and removed  Why?-foundation1-jpg   Foundation Cut and removed  Why?-foundation2-jpg
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/3/13, 1:18 PM
Jeffrey R. Jonas's Avatar
Default Re: Foundation Cut and removed Why?
PDF won't download.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 4/3/13, 2:40 PM
Randy Mayo, P.E.'s Avatar
Randy Mayo, P.E. Randy Mayo, P.E. is online now
Larry,
Was the cutout section of concrete, in the first photo, the section cutout of the basement wall for the access hole into the crawlspace?
The trench is the overdig left when excavating for the basement that was never backfilled.
The only issue I see is the garage area is usually backfilled with gravel before pouring the garage floor. I don't see any backfill material looking under the garage foundation wall.
Foundation Cut and removed  Why?-jump-footing-jpg
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Old 4/3/13, 3:06 PM
Hey Randy,
The cut out concrete was from the wall of crawlspace below/at the gararge floor slab.
Old 4/3/13, 3:19 PM
Christopher Currins, CMI Christopher Currins, CMI is offline
Certified Master Inspector ®
Originally Posted by jjonas View Post
PDF won't download.
It did for me. Here it is in jpg.
Foundation Cut and removed  Why?-untitled-jpg
Old 4/4/13, 12:20 AM
ROBERT YOUNG's Avatar
ROBERT YOUNG ROBERT YOUNG is online now
Location: Ville de Montréal - Borough Côte-des-Neiges-Notre-Dame-de-Grâce
I opened the download.
It looks like venting.
If you see no signs of installation for wiring or mechanical fasteners for equipment, I will go with venting the partial foundation.
Question I would ask myself.
Any windows in the basement?
Any signs of high RH, efflorescence, water staining or past flooding?,
Any bad weather for freak storms? is the trench in the crawl space you speak of look like water ran a course?
Was that used to empty a water dam in the crawl space.
IMO You are a solid HI without a doubt. I would write up what I observed and move on.
Hope that helps.
All the best.
Robert Young's
Montreal Home Inspection Services Inc.
Our Motto: Putting information where you need it most, "In Your Hands."
https://montreal-home-inspection services.com
https://home-inspectionservices.com
