Old 11/17/12, 8:08 PM
Joe Funderburk, CMI's Avatar
Joe Funderburk, CMI Joe Funderburk, CMI is online now
Certified Master Inspector
Question Foundation straps in brick - building inspector says it's OK
What do you guys think? New home. NC building inspector OK's it after I call it a structural defect in my report.
Foundation straps in brick - building inspector says it's OK-itsok-jpg Foundation straps in brick - building inspector says it's OK-straps-brick-jpg
Leading strap manufacturers say you can't put straps in red clay brick or 4" masonry block.
www.strongtie.com/ftp/catalogs/c-2011/C-2011-p034.pdf
www.uspconnectors.com/pdf-full-line-2010/32.pdf
Theodore Roosevelt
Joe Funderburk, CBO, CMI
Angie's List Super Award Winner 2016, 2015, 2014, 2013, 2012, 2011, 2010.
Ph: 704-351-1776
www.aohomeinspection.com
Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/17/12, 8:27 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
Default Re: Foundation straps in brick - building inspector says it's OK
You forgot to read where it says Foundation anchorage, spaced as required to provide equivalent anchorage to 1/2" diameter anchor bolts.
Those are equivalent.
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 11/17/12, 8:35 PM
I'm not sure you follow my point. Of course straps are equivalent to bolts. But neither can be used in red clay brick or 4" block.
The manufacturers instructions I posted state:
"Do not use in red clay brick."
"Not for use in slabs poured over foundation walls formed of
concrete block or with brick and 4" masonry block stemwalls."
Theodore Roosevelt
Ph: 704-351-1776
Old 11/17/12, 8:40 PM
Looks to me like the brick cavity is all filled with concrete grout and will be buried below grade, so that pretty much looks like a composite system to me that would meet the proper anchorage.
Old 11/17/12, 9:50 PM
It's a raised foundation. A crawlspace foundation. Nothing is going to be buried below grade. Regardless of buried or not, you cannot put bolts or straps in red clay brick.
Theodore Roosevelt
Ph: 704-351-1776
Old 11/18/12, 11:26 AM
Well, I guess you would not like this one either, huh!!!
Foundation straps in brick - building inspector says it's OK-endicott_brickdetails0410-jpg
Brick Construction Details
Old 11/18/12, 3:47 PM
Attachment 60296
That strap extends to the concrete foundation, so yes I do like it.
Theodore Roosevelt
Ph: 704-351-1776
Old 11/18/12, 4:17 PM
Marvin Maizel's Avatar
Marvin Maizel Marvin Maizel is online now
I'm with you Joe,
I would reject it and ask to be overturned by the design engineer. He is the one that is responsible. Did the stamped drawings show that detail?
Old 11/18/12, 5:08 PM
Isn't it possible since this appears to be brick and a 4" CMU back-up with cavity, that they might have filled the cavity with grout and then chipped the brick to move the strap to the exterior portion of the wythe?
Engineered design wasn't it?
Old 11/18/12, 8:10 PM
Emmanuel J. Scanlan, TREC# 7593 Emmanuel J. Scanlan, TREC# 7593 is offline
Attachment 60284 Attachment 60285
As a "Licensed Building Official" yourself you should be familiar with the following IRC references.
R104.1
R104.4
R104.10
R104.11
According to the "OFFICIAL CORRECTION NOTICE" you have posted Marcel has asked a very appropriate question.
Given all that has been presented here the question is not what do we think? Instead the questions are:
  1. What do you think after this correction notice was posted?
  2. If you disagree with the correction notice, and feel so strongly about it, what actions do you intend to take?
  3. As a "Licensed Building Official" what actions do you have available to you to ensure your client does not suffer from an injustice you perceive to be occurring?
The information and viewpoints you provide might assist other Inspectors in understanding the role and responsibilities of the AHJ and their "Licensed Building Official" members.
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 11/18/12, 9:27 PM
Bruce R. Grant Bruce R. Grant is online now
Hey Joe, I have just one question as I can not see the brick personally and that is are you shure it is a true clay brick and not a composite or concrete manufactured brick? Not many clay brick seen up here in many years.
Bruce Grant
Done Right Home Inspections
Washago Ontario Canada
http://www.muskokahomeinspection.ca/
http://www.orilliahomeinspector.biz/
Old 11/19/12, 10:02 AM
Drawings around here do not show that level of detail. Commercial, yes. Residential, no.
Theodore Roosevelt
Ph: 704-351-1776
Old 11/19/12, 10:15 AM
1. I think the inspector abdicated his duty to enforce the building code-twice (at the original open floor inspection and at the return trip because of my report).
2. I advised the client to contact the strap manufacturer and see what they say about it. I also send the photos to a structural engineer friend of mine for his comments.
3. I have no authority in NC. My license is in SC. But I did tell the client that the builder and the inspector are licensed by the State of NC and he has a right to file a complaint with the State.
Theodore Roosevelt
Ph: 704-351-1776
Old 11/19/12, 10:16 AM
Red clay brick is commonly used in the South.
Theodore Roosevelt
Ph: 704-351-1776
Old 11/19/12, 2:54 PM
I see NC building inspectors that constantly miss things or worse simply sign off on them and move on....especially in Mecklenburg County (Charlotte). In such cases I simply copy code and/or manufacturer information and then direct my clients who they can contact including the North Carolina Licensing Board for General Contractors.
I have a couple of licensed engineers that I use from time to time however even in cases like yours for the record they often will not comment on issues other than referring to manufacturer info.
Jeff
PS. I know the inspector you are talking about personally.....he is usually pretty sharp...
Exterior Spray Foam rcooke Canadian Home Inspectors 8 4/14/11 4:16 PM
Renovating Your Basement for Livability mkyriacou Canadian Home Inspectors 0 10/22/09 12:45 PM
Common Defects List by Age of House trausch Inspection Education & Training 10 6/12/06 5:52 AM
