Old 7/6/13, 11:15 PM
Geoff Martin Geoff Martin is offline
Please Note: Geoff Martin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Are these horizontal cracks in the foundation dangerous?
My family and I have just moved into a duplex that weíre renting. The house is joined to another house. We share one wall with the other house. Weíre not in a row of townhouses.
Iím not a structural engineer, but have concerns about the foundation of the house. Iíve heard that horizontal cracks are bad in a foundation and we have some very long ones in the foundation that span the length of entire walls. One of these wall long cracks on one of the west walls extends right into the south wall and continues on. Iíve attempted to attach pictures of this particular crack to this post, but seem unable to.
The cracks have been patched/filled with concrete at some point, and it looks like the filled concrete has been sanded down to smooth it out, so itís really hard to tell how wide the cracks actually are. The foundation walls donít appear to be bowing, but Iíd like to understand better whether or not the cracks are dangerous. Thereís also vertical cracks in the foundation.
I know itís hard to judge from just photographs, but are these cracks dangerous, considering that the walls are flat and flush? Whatís the difference between a horizontal crack thatís dangerous and one thatís not? Or are all horizontal cracks something to be concerned about?
Thanks in advance to anyone who takes the time to reply.
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/9/13, 10:33 AM
Erik Schmidt Erik Schmidt is offline
Default Re: Are these horizontal cracks in the foundation dangerous?
How old is the house? All concrete will develop cracks the older the house, the more cracks,
How wide are the cracks? Hairline cracking is usually not a structural problem.
Horizontal cracking near or below grade may be caused by frost or the expansion of clay based soils when they get wet. Horizontal cracking often occurs shortly after the house is built, and may be the result of poor practice when backfilling. If the foundation walls are not being pushed out or over, there is probably not a structural problem
Are the cracks moving or getting wider? Stable older cracks are probably not a structural problem.
Are the house floors, walls, level doors, window frames are not pushed out of shape? (is the foundation doing what it is supposed to) Many foundations will settle somewhat, the older the structure the more settling can be expected, and be acceptable.
Without your pictures it is impossible to tell, but from what you say it does not sound like you have a structural problem particularly if the house is older. If it has been standing for 30 or more years it is probably not going to fall over real soon.
Cracks will leak water, which is another issue entirely, make sure your landscaping, gutters, etc.. direct water away from the foundation. Efflorescence (white crystaline deposits) in or around the cracks indicate water is leaking through the cracks. Mr. Bubber will have plenty of advice for you should this be the case.
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 7/10/13, 5:57 AM
john bubber's Avatar
john bubber john bubber is offline
Unmoderated Guest
Please Note: john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mr Erik, good points and Q's
Geoff,
SOME horizontal cracks might NOT get worse/widen (without ANYTHING being done)
SOME horizontal cracks will get worse over TIME.
SOME horizontal cracks can get worse/widen suddenly.
The fact that somebody apparently filled 'em with concrete on the inside doesn't do squat.
HERE/photo, a horizontal crack and verticle crack were patched/concrete on the inside.....
http://picasaweb.google.com/10104903...86423566918322
ZOOM IN and you'll see the patching.
Same house, what needed to be done.....(the outside of the wall)
http://picasaweb.google.com/10104903.../November32011
Click each individual pic to ENLARGE
As Erik said, no pictures so its more difficult to say/help and its still best to be ON SITE.
This article, at least whats in this part-1 is pretty much right on....scroll down to PAGE 3
http://www.plickandassociates.com/newsletters/Mar06.pdf
This article also helps explains some sht, about 1/2 way down, Basement Wall Damage
http://www.fairfaxcounty.gov/dpwes/p...marineclay.htm
You/others see what ya see on the inside but that does NOT explain what can and does occur OUTSIDE....see deteriorated blocks and joints here.....
http://picasaweb.google.com/10104903...65133328086770
Could post some news stories of homeowners who had a wall cave in, only had small crack(s) visible on the inside so, pictures wouldn't hurt but even then we/NOBODY can tell ya what is going to happen to the wall(s),cracks in the future. Can only explain what we've seen for decades and what is BEST for them and, lol, its not any inside work/system/patching.
And please watch this short video......this is what i mean....and imo, NEVER EVER trust an inside system company....NOPE! https://www.youtube.com/watch?v=jLjltBxHKfU Foundation problems in Pennsylvania, got milk?
Little Brown Bird, J Beck & E Clapton https://www.youtube.com/watch?v=dSnsyzfhY_E .....Bubba got a bird for duh winter, and Bubba got a bird for the spring
Room over garage mivie Structural Inspections 20 1/17/10 11:08 AM
Dampness in basement- new construction jcundiff General Inspection Discussion 47 6/21/08 12:35 PM
