Old 11/7/18, 5:19 PM
john bubber's Avatar
john bubber john bubber is offline
Unmoderated Guest
Please Note: john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default on the inside of block foundation wall you see step cracks, NOT a vertical corner crk
...and on the inside you do not see horizontal cracks at the top of the first block above basement floor but on the OUTSIDE it's a different story and this is one way interior basement drainage companies lie to and scam many homeowners
OUTSIDE video, vertical corner crack
YouTube
Outside and INSIDE look at same corner............
YouTube
And then we have those who will will inspect or water-diverting companies will come out and LIE to homeowners, tell them, Oh your house is settling etc and you need our wall anchors and piers etc.... AND lol they won't dig and repair these cracks, so that water DOESN'T enter and cause mold etc, and they don't remove clay soil and possible tree roots off the wall, truly incompetent scammers.
Say again, looking at....inspecting, foundation walls like these on the inside doesn't tell you the entire story.
Block walls here.... what does this guy say.... and do....??? lolloollllllll UN_______-----------BE-------_________lievable!!!!! Scam, lies, incompetence!
YouTube
Hey man, 2:50 and 5:50........................ the MOLD is there because water has been and will CONTINUE to enter the blocks on the OUTSIDE!! hahhahahaaa duuuuuuuuh!
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/8/18, 8:43 AM
Wayne B. Wilson, TN 439's Avatar
Wayne B. Wilson, TN 439 Wayne B. Wilson, TN 439 is online now
Default Re: on the inside of block foundation wall you see step cracks, NOT a vertical corner
It is hard to tell buyers when so many are out there selling lip stick for pigs.Had 2 this week , One listen one not so much
Wayne Wilson CMI
East TN Home Inspections LLC
865-256-1490
https://www.myhomeinspection.net/
Old 11/9/18, 3:09 AM
Unmoderated Guest
hear you Wayne, hope business is booming for you.
Old 11/10/18, 7:45 PM
James F. McKee's Avatar
there was a lot of old man sounds in that video as someone was crawling down in that hole....just sayin....
Jim McKee
Lorain, Ohio
440 225 8688
www.classicinspector.com
Old 11/11/18, 12:06 PM
Unmoderated Guest
lllllllllllooooooooooooollllllllllllllllllllllllll l yes sir Jim, part of the problem was old man tooth infected ooooouuuuuuchie, part just being old! hahhaaaa
