This one was easy to identify as it had not been patched or gaps concealed.
Other signs can be apparent even when not significantly out of level, thought I’d share.
I’d say that one of the most common signs of rotation or similar defect is a V or tapered crack where firebox meets face of fireplace, such as brick or similar. Maybe you’ve seen repaired grout in this area?
Soils, likely via negative grade (assumed)… would appear half of house right through garage and porch have settled. Was to be a fixer, and it may be for somebody, but not the buyer today. Direct runoff from street towards house and garage for 50-60 years… Water wins!
And let’s not forget the ole Rampart pre cast. Rotation, cracks and separation from face, all fairly common to run across and see problems with. For anyone else in SoCal… a good doc to read on pre cast is
If you’re not familiar with these and you’re reading this document, you just thought “Oh my” I’ve seen a bunch of these and they seemed fine. As they say, you don’t know what you didn’t know until you know
