Old 11/8/18, 6:01 PM
Randy Mayo, P.E.'s Avatar
Randy Mayo, P.E. Randy Mayo, P.E. is online now
Default Manufactured House Cross Beam Connection
FYI - The attached free graphic shows one method of providing a permanent foundation for a manufactured home by pouring a concrete basement or crawlspace with beam pockets. Multiple cross beams are placed in the pockets typically with a column or pier at mid-span. The steel frame of the manufactured home sits on top of the cross beams. In order to fully comply the cross beams need a retainer at the ends to prevent uplift and the steel frame of the manufactured home should be bolted or welded to the cross beams.
Manufactured House Cross Beam Connection-beampocket-jpg
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/8/18, 10:24 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Default Re: Manufactured House Cross Beam Connection
Nice graphic, Randy. Thanks.
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 11/9/18, 8:21 AM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Nice graphic Randy.
Grade SAE 8?
Considering the difference, wouldn't A325 suffice?
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Old 11/9/18, 9:45 AM
Yes, an A325 would work. I specified A325 on all the bridge designs I did back in the early 80's, but around here you would have to order them. All the farm supplies carry the standard Grade 2 utility type bolts or SAE Grade 8 bolts. I suspect being in farming country they stock the SAE Grade 8 for machinery.
Randy Mayo, P.E.
573-201-8162
Old 11/9/18, 10:47 AM
No not really, all the structural building I ever down was always supplied with the A325 bolts or the torx head from the structural fabricator, and came with the deliveries. It is not a store bought item.
Either or I believe the grade 8's are a lot more money though.
