ok so lool homeowner apparently spent $20,000....
on another interior basement system and wall anchors or something like that and, they did NOT dig ummm, EXXXXXcavate. They did not remove, relieve, reduce the cause (s), the weight, soil pressure, underground roots, porch footing…whatever it is… that caused the cracks in wall, bowed wall and subsequent leaks through the dumb cracks! And obviously they did not waterproof the exterior wall :35… 'previous contractor $20,000 ish.
now this guy/company is pretty much going to do the same things! lol 4:45… going to install another interior basement system… WHY? Holy SMELL man.
Putting beams, braces, wall anchors or whatever against the inside of the wall (whether one straightens it or not), will NOT remove, reduce, relieve ANY of the exterior cause(s) of… why the wall bowed in, cracks, leaked!
https://www.youtube.com/watch?v=lB-O9aDo7PM …‘Exposed failed foundation repair rip off’
A wall can continue to move, bow, crack if one doesn’t remove, reduce, relieve the cause(s) on the friggin exterior of the wall, hello.
Sheesh, if a big tree limb falls/lands on your ROOF… and causes damage, are you going to leave it there, leave it on your roof and instead go up in the attic and install some sort of interior water diverting system up there and install some type of moronic ‘roof braces’, huh? Come on man.
If you scroll down to, Basement wall damage, cause, resolution… https://www.fairfaxcounty.gov/dpwes/publications/marineclay.htm … do they tell homeowners to install an interior basement system and some beams, anchors etc?
more food FER thought, sheesh man, why did this wall bow in, what caused multiple exterior cracks in foundation walls and caused basement to leak???
https://www.youtube.com/watch?v=ABUnDJ0ZSn0 outside
So your trying to tell Bubba to… lol, install an interior basement system and piers or wall anchors or beams and a sump pump huh???
Some morons incompetently say, oh just raise n slope the grade or, add 5,005’ long extension to downspout or, apply Drylok on inside walls
https://www.youtube.com/watch?v=NsxGRQbf_Nc inside view of same basement wall
Somebody plzzzzzzzz inform me exactly how installing ANY interior basement system (as King Piers or previous knothead contractor did for $20,000) or installing beams, wall anchors etc on inside would have REMOVED the CAUSE of the wall bowing in, cracks, leaky basement, go ahead make Bubba’s day
Dirty Bubba, i mean Harry https://www.youtube.com/watch?v=mevxenJ6Mtc
On quite a few of these BOWED IN, cracked walls… it’s the clay soil that CAUSED the damage and so your going to LEAVE that soil against the wall and leave the cracks open so that more water can enter and further deteriorate the blocks n joints and instead install a STUPID pathetic waste of money interior basement system huh?
One of a few builders who ‘get’ the importance of backfilling with all gravel, not dirt, BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEcause that dirt, clay can " cause cracks in walls, cause leaks and in worst case cause wall to bow inward!!! http://www.dwightyoderbuilders.com/concrete.cfm
