Old 7/15/17, 7:46 PM
Kenneth Blair, CMI Kenneth Blair, CMI is online now
Default Planks under metal roofing
Can anyone tell me what has caused the wood fibers in the roof decking planks to be heavily furring. It was on several of the planks and pretty heavy on some. There was no elevation in moisture on the planks but there were some signs of past leakage. This house was an older home that had been moved to its current location. Typically I don't touch something that looks this was as usually I think of growth/mold possibly. But I did touch this and it appeared to be the wood fibers and possibly rot.
Planks under metal roofing-img_4934-jpg   Planks under metal roofing-img_4939-jpg
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/16/17, 3:41 PM
Thomas Witt's Avatar
Thomas Witt Thomas Witt is offline
Certified Master Inspector ®
Default Re: Planks under metal roofing
Just recommend testing for mold to start.
Old 7/18/17, 11:18 PM
Randy Mayo, ,P.E.'s Avatar
Randy Mayo, ,P.E. Randy Mayo, ,P.E. is online now
You said the building was moved from another location. Could the building have been exposed to salt water spray like near the ocean?
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
