Old 10/11/18, 4:08 PM
Randy Mayo, P.E.'s Avatar
Randy Mayo, P.E. Randy Mayo, P.E. is online now
Default Ridge Beam/Ridge Board
FYI - Free graphics showing ridge board and ridge beam
Ridge Beam/Ridge Board-ridgeboard-jpg   Ridge Beam/Ridge Board-ridgebeam-jpg
Randy Mayo, P.E.
573-201-8162
www.rlmengineers.com
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/11/18, 8:32 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
Default Re: Ridge Beam/Ridge Board
Nice graphics Randy, but shouldn't the Ridge Beam look more like this; Ridge Beam/Ridge Board-maxresdefault-jpg, considering that with a ridge beam, it also needs to hold the exterior walls from spreading?
JMH
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
The InterNACHI Awards Committee is the final authority of issuance of any award the committee offers and any rules updates.
Old 10/11/18, 9:24 PM
Marcel,
It can be any configuration big or small depending on the load and span length. My graphic depicts a small ridge beam and yours is on the large size. The graphic I made depicts what I saw today. Here is the photo, although it's too small or over-spanned for a 2x6 I just wanted to show the difference to the buyer.
Ridge Beam/Ridge Board-p1040472-jpg
Randy Mayo, P.E.
573-201-8162
Old 10/11/18, 9:57 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
It's OK to lap on top of the beam (typically an exposed structural ridge), but the rafters should actually overlap at least 6". This means you need to cut a corresponding slope to match the opposite side. In my photo, the lower drawing shows a single rafter top cut ready to install, and the upper drawing two rafters installed bearing on a structural ridge with 3 nails through the lap, offset from the center so that the building inspector can see the nailheads once the blocking is installed. (not really drawn correctly. Structural ridges are usually at least 3.5").
Of course, for rafters 24" OC there'd be 22 7/16" anti-rotational blocks down the center of the ridge. On a really clean framing job they'd be ripped to the same angle as the pitch, resting on the ridge, and flush with the top of the rafters to provide perimeter diaphragm nailing for the sheathing.
Marcel's photo shows hangered rafters, very common in modern framing, and would not require collar ties. An older house would have rafters nailed, and collar ties installed every 4'.
Randy's photo shows rafters bearing on top of a non-structural, non-exposed ridge, with no collar ties, which is a little unusual, and I can't see any blocking between rafters, and if the rafter overlap at the peak were only 1.5", as it appears to be, I'd call it poor quality framing and be looking for other framing problems. Lap nails that close to the ends of the boards (¾") are going to split the board ends.
Ridge Beam/Ridge Board-lapped-rafters-jpg
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
