Old 10/31/12, 11:06 AM
Frank J. Buttermore Frank J. Buttermore is offline
Default Has anyone ever seen this?
I'm looking for any info I can find on a structural block I have never seen in use before....this is a pre-1900 house and these blocks are in use for the entire foundation below grade....that being said, foundation has typical moisture issues, etc. Looking at these blocks, I can't believe they hold up the house......they appear to be made of concrete.
Thanks!
Has anyone ever seen this?-photo-jpg   Has anyone ever seen this?-photo-2-jpg
Frank Buttermore
HTI Inspection Services, LLC
Howell, MI
www.htiinspectionservices.com
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/31/12, 11:09 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
Default Re: Has anyone ever seen this?
http://historicbldgs.com/terra_cotta.htm
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 10/31/12, 11:10 AM
Roy D. Cooke, Sr's Avatar
Looks like Tile Blocks to me Not very strong damage easy and when I saw them used it was in Apartment building as divider walls around 1960 .
Never seen them since
Old 10/31/12, 11:29 AM
Thank you both, gives me more to go on.....
Frank Buttermore
Howell, MI
Old 10/31/12, 11:35 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Certified Master Inspector
I am truly amazed at times when I see the methods of construction used in areas where the earth stands still. This type of construction would have "taken care of itself" long ago if it were in CA...
I'm interested to know how you "justify" recommendations for any corrective or proactive action when you come across this stuff when it has been standing for more than a hundred years, and there are no indications that it may be failing. What (if anything) can you expect to happen over the next hundred years that might change the integrity of this structure?
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/31/12, 12:55 PM
I sruggle with that as well, Jeff. In my area, we have a lot of older homes on fieldstone foundations that look terrible but yet, are 100-150 years old!My usual take on it is to point out the big picture (age and O/A condition) and then recommend a secondary inspection by an "expert" if they are not comfortable with my findings. 99% of the time, people understand that a house this old is non-conforming with todays standards and take their chances.....In our area, SE's tend to overreact and overkill their recommendations...
Frank Buttermore
Howell, MI
Old 10/31/12, 12:57 PM
PS....if there were earthquakes happening in Michigan like you guys see in Cali, half of the houses in this state would fall over.......
Frank Buttermore
Howell, MI
Old 10/31/12, 2:51 PM
John Harrison, CMI's Avatar
John Harrison, CMI John Harrison, CMI is online now
Not a big conflict
House was built by whatever standards or practices were available at the time it was built. Simply because it is outdated and non-desirable today does not mean it needs to be corrected. It is never our job to predict the future, only what we see at the time of inspection.
Foundation is straight, undamaged, supporting the house, then no problem.
Report any defect of the current structure.
Is it broken, damaged, falling over that may need to be repaired
If not then I would verbally mention to the client that it is a weaker type of foundation that may need excessive maint, or repair in the future. I remind them that so far the foundation has stood well for a house that was built in 18XX.
<a href=http://www.bluffshomeinspection.com target=_blank>http://www.bluffshomeinspection.com</a>
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Council Bluffs Home Inspector
Iowa Home Inspector Council Bluffs - Facebook
Active Rain Member
Old 11/5/12, 5:53 PM
Preston L. Halstead, HI549 Preston L. Halstead, HI549 is offline
We have houses here near the ocean built around 1900 with that 6" clay block from the footing to the roof with stucco surface. Still there with all the hurricanes.
Preston L. Halstead
VP FL Home & Insurance Inspectors Chapter
Elite Property Inspection & Management
LICENSED GENERAL CONTRACTOR CGC1515203
LICENSED BUILDING INSPECTOR BN6262
LICENSED HOME INSPECTOR HI549
561-420-0277
HOME INSPECTION ~ WIND MITIGATION INSPECTION
Serving Boca Raton, Boynton Beach, Delray Beach, Juno Beach, Jupiter, Lake Park, Lake Worth, Lantana, North Palm Beach, Palm Beach, Palm Beach Gardens, Royal Palm Beach, Wellington, West Palm Beach.
Old 11/5/12, 6:03 PM
Bob Elliott's Avatar
Very common in apartment buildings built around 1900 or so.
Very strong but will crack easy if drilled.
No issues.
Go here to learn more https://www.google.com/search?hl=en&...CsXGygHRrIHwBA
(clay tile)
Old 11/5/12, 7:53 PM
Marcel R. Cyr, CMI's Avatar
Marcel R. Cyr, CMI Marcel R. Cyr, CMI is offline
Certified Master Inspector ®
Terra Cotta as Mikes Link shows.
I repaired a house back in 1973 where the basement walls were all constructed with it and plastered over.
Sorry, no photo.
CMI 2004-2017 Retired
Awards Committee Member
U.S. Member of the Year Winner 2009
45 Years Residential/Commercial Builder
Old 11/5/12, 8:12 PM
Sorry, no photo.
trucural terra cotta/clay tile,pretty much the same thing.
Here is a link to a good This Old House article from a report I did in January of 2008.http://www.oldhouseweb.com/how-to-ad...ra-cotta.shtml
Below are a few of the pictures and comments from my report on this condo conversion of the old Goldblatts dept store (downtown Chicago)
The majority of the wall surfaces are the terra cotta with the drywall primarily in the laundry bathroom areas.
Observations: Material failure in glazed architectural terracotta is necessarily complex. For this reason, it is
generally advised that the examination and repair of this material should be the responsibility of an
experienced professional. Few restorationists have experience in the inspection, repair and replacement of
glazed architectural terracotta. This is certainly never the province of the amateur or the most well intentioned
but inexperienced architect or engineer. There are some methods of internal and external inspection and
analysis which are relatively simple to the trained professional. Other methods, however, are expensive, time
consuming, and only in the experimental stage at this writing. These all generally preclude the use of anyone
but an experienced professional.
Windows appear to be missing frame screws but
it may have been found to cause damage to the
terra cotta when installing.I would find out if all
these windows in the building were installed in the
same manner
Window frames were warped from using wedges to force fit in place.
[ATTACH]Has anyone ever seen this?-structural-terra-cotta-beam-jpg[/ATTACH]
Has anyone ever seen this?-structural-terra-cotta-jpg
Old 11/5/12, 8:15 PM
Key word this ...."Structural Terra Cotta"...."Structural Clay Tile".
Old 11/5/12, 8:19 PM
Yes Bob, good article.
The grooves, or ribbing, on all four sides help mortar, plaster and stucco adhere to the surface.
Above grade, plaster is applied directly to the interior side of the structural terra cotta blocks. The exterior is often coated with stucco.
Old 11/5/12, 8:21 PM
I seem to recall this stuff is always found in what can be termed fireproof buildings.
Pretty sure you can look up me asking about it right here on the forum somewhere under 1/6/2008.
Marcel you are most likely one of the guys who answered at that time.
Guess I just take too many pictures...useless.lol
