I’m inspecting a slab house today I noticed how the soil has pulled away a bit from the foundation due to the hot weather. As I am looking closer there does not seem to be a footing around the house. I could stick my screw driver under the slab (about 8 inches) in several different areas. Shouldn’t there be a continuous footing around the house or am I mistaken here. Thanks in advance for the input.
Was it a house addition?
Yes, there should be a footing. If a mono-slab, it would look something like this:
No it is not an addition. I even checked a couple houses around this one and they were the same way. The house was built in 2004 also.
Are you in Mexico?
ROFL, no Im in Missouri.
"R403.1.4 Minimum depth. All exterior footings shall be placed
at least 12 inches (305 mm) below the undisturbed ground surface.
Where applicable, the depth of footings shall also conform
to Sections R403.1.4.1 through R403.1.4.2.
Commentary: Footings are required to extend below the ground surface
a minimum of 12 inches (305 mm). This is considered
a minimum depth to protect the footing from
movement of the soil caused by freezing and thawing
in mild climate areas. See Section R403.1.4.1 for general
frost protection requirements."
“R403.1.4.1Frost protection. Except where otherwise protected
from frost, foundation walls, piers and other permanent supports
of buildings and structures shall be protected from frost by one
or more of the following methods:
1. Extended below the frost line specified in Table
R301.2.(1);
2. Constructing in accordance with Section R403.3;
3. Constructing in accordance with ASCE 32; or
4. Erected on solid rock.”
Thanks Joe, I have that. I just cant imagine all these homes in this subdivision being built like this and the Code inspectors not catching this or something.
Are you sure it isn’t just a localized void (air pocket)?
Are you in mexico lol Joe you crack me up buddy.
Just curious…
How did you know this? Did you inspect the house prior, during cold weather? Inquisitive minds want to know.
That’s a good find, go back and take more pictures for your library.
Mexico, that’s hilarious. I was going to guess Arkansas.
Well, we are an INTERnational organization!
We are in Missouri. After inspecting for awhile, nothing surprises me any more. Some contractors will try to get away with anything In Missouri.
Well, Mark, it sure would help if you listed your location!
All new people: Complete your profile B4 your 1st Post!
Looks like probable frame const. What was the t of the slab, and what type of slab is normally used around wherever you are?
I can’t tell something exactly from your discussion, i need to study it closely i am your country mate, please contact me i visit that house myself.
