Old 2/13/19, 3:16 PM
James Eubank's Avatar
James Eubank James Eubank is offline
Default Can you tell me about this wall structure?
House built 1903. Walls are comprised of vertical 2x6 spaced 24 inches apart. Pieces of bricks in between the 2x6. What can you tell me about this type of wall construction? See photos!
Can you tell me about this wall structure?-20190213_094643_hdr-jpg   Can you tell me about this wall structure?-20190213_094704_hdr-jpg   Can you tell me about this wall structure?-20190213_095035_hdr-jpg
Certified Property Inspector
Home - Commercial - International
Love my family. Do the best quality of work I can.
Live simply so that others can simply live.
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/13/19, 6:18 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Default Re: Can you tell me about this wall structure?
Interesting. I've never seen it before, but I'm in FL. Bob Vila might know.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 2/13/19, 7:42 PM
Brian Abrahamson Brian Abrahamson is offline
James, what you are seeing is what they called in the old days as brick nogging. The concept was to add thermal mass to the walls (acting like an insulation from air infiltration and wind barrier), which at the time were generally balloon framed. It also helped as a fire block
Old 2/13/19, 9:34 PM
Thanks, Brian, that's super helpful!
Old 2/14/19, 12:08 PM
ROBERT YOUNG's Avatar
ROBERT YOUNG ROBERT YOUNG is online now
Appears to be structural masonry. Do not quote me on that.
Exterior walls are likely 2 or 3 brick wythe.
Image 3 is likely a bearing wall.
Image of the brack on the exterior please.
Robert Young's ​Montreal Home Inspection Services Inc.
Home Inspections & Building Inspection Services.
Covering on and off islands in greater Montreal and Laval. (514) 489-1887 or (514) 441-3732.
Our Motto: Putting Information Where You Need It Most, "In Your Hands."
https://montreal-home-inspection-services.com
Old 2/14/19, 12:43 PM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Certified Master Inspector ®
brick nogging wall - Google Search
On The Level Inspection
Gatineau, Québec
Tags
2x6, wall, bricks, pieces, construction
