As required for the exterior coarse the two articles I read were pull down attic stairs and attached garage safety. Besides the items listed in the pull down stairs article I also point out the weight limit that is usually printed in the attached label. This is usually 250 lbs. As far as garage doors to the home one of the most common things I see id the self closing hinge being disabled., if the hinge is present I try and explain to the client how to adjust the hinge so the door can self close. But my report always recommends that it be done by a professional.
Rough homework eh?
