[size=]Welcome to another round of Questions of The Week ![/size]
Questions of the week:
Introduction and requirements:
A member of the Award Committee will post a question, at a random day/time.
A competing member may make one post per question thread to answer the question and the member’s winning entry must have all parts of the question answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Winnings will be limited to no more than 6 times in a given year, the objective is to allow as many Members a chance to win as possible.
Any disregard to the above and divulging the correct answers will forfeit the weekly winnings.
So please refrain from participating if you have already won in the maximum for the Year.
First correct answer (as judged by the Awards Committee or Poster of the Question) wins.
The lucky winner will get a case of “Now that you’ve had a Home Inspection Books” shipped to them at their address on file. Make sure your Address on File with Inachi is correct.
Winners of the Question of The Week shall request their prize by emailing fastreply@nachi.org and submitting their Mailing address for shipping.
Allow 2 weeks for delivery.
THANKS for being here and good luck!
1. Flashings serve two major purposes. One is to direct water away from building elements susceptible to deterioration by staining, erosion, frost damage, and corrosion. The other is to
A. add another insulating layer.
B. provide an attractive trim feature on the exterior of a building.
C. prevent water from penetrating the building.
D. provide a substance to which veneers can be attached.
2. Creating a flashing detail that is easy to build will greatly increase the likelihood that the flashing will be built to perform poorly.
True
False
**3. Which of the following substrates for self-adhering flexible flashing may require a primer?
A. solid wood
B. window flanges
C. concrete
D. metal work
4. A drainage plane typically consists of
A. a water repellant material, or weather resistive barrier, located on the inner face of a cavity wall, connected with flashings to direct water to the exterior through weeps at the base of the wall.
B. a water repellent material, or weather resistive barrier, attached directly to the back side of masonry, connected with flashings to direct water to the weeping tile.
C. a water repellent material, attached to rigid foam insulation, running the full length of a wall, and exiting through a brick course to the exterior.
D. flashing only, located on the inner face of a cavity wall, directed to the exterior through weeps at the base of the wall.
5. Components of through-wall flashing may include
A. spray adhesive.
B. mortar.
C. nails.
D. prefabricated corners, dams, and other pieces.
