Welcome to another round of Questions of The Week!
Please Read the Introduction and requirements, changes may have been made.
A member of the Awards Committee will post questions, at a random day/time.
The competing member and “Sir Roy” may make one post per question thread to answer the questions and the member’s winning entry must have all parts of the questions answered completely in that one post. Editing your one answer post allowed will result in disqualification.
Any disregard to the above and divulging the correct answers or giving hints/references will cause a disqualification.
First correct answers (as judged by the Awards Committee or Poster of the Questions) wins.
The lucky winner will get a case of “Now that you’ve had a Home Inspection Books” shipped to them at their address on file. Make sure your Address on File with Inachi is correct.
Winners of the Questions of The Week shall request their prize by emailing fastreply@nachi.org and submitting their Mailing address for shipping.
Allow 2 weeks for delivery.
Best of luck to everyone!
1 - With hot water heating, using radiant heating, what is the maximum ceiling temperature you would want to have in a room with 8 foot ceilings?
a. 70 degrees F
b. 90 degrees F
c. 110 degrees F
d. 130 degrees F
e. 150 degrees F
2 – Which of the following is a safety hazard?
a. The main fuses have a lower rating than the service entrance wire.
b. The main fuses have a higher rating than the service entrance wire.
c. The service box has a higher rating than the service entrance wires.
d. The service box has the same rating as the service entrance wires.
e. The distribution panel has a larger rating than the service entrance wires.
3 – The Hartford loop in a steam system:
a. Automatically maintains the water level
b. Is an equalizer that insures that pressures are equal above and below the water line in the equipment.
c. Precludes siphon action if the unit develops a leak
d. All of the above.
4 – What roof material doesn’t require an underlayment?
a. Asphalt shingles
b. Slate
c. Wood shingles
d. Wood shakes
5 – There is a gas furnace in the basement and you notice your glasses are fogging up:
a. Caused by improper appliance venting
b. Caused by excessive heat
c. Caused by broken humidifier
d. That is normal
