Canadian Home Inspectors This is a place for Canadian InterNACHI inspectors and other home inspectors in Canada to discuss local home inspection topics.
Old 3/11/06, 6:51 PM
Allan Spisak Allan Spisak is offline
Community Guest
Please Note: aspisak is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default GFCI's & Garage Door openers
I learned a new lesson, before jumping into testing exterior outlets to see if they are GFCI protected, check to see if the garage door opener is plugged or wired into the exterior outlet circuit.
Why - because yesterday we tested the exterior outlet and tripped the GFCI, the reset was in the garage and the garage had no other access than to break the glass in the door!
I inspect so others may learn.
www.aciss.ca
Old 3/13/06, 9:05 AM
Rob A. Parker Rob A. Parker is offline
Send a message via ICQ to rparker
Please Note: rparker is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: GFCI's & Garage Door openers
Allen I think I would call that out in my report.Just sound strange that the out door outllets are tied to the garage door opener.I have never come across that before and it becomes a problem when the only door to the garage is the car door. Just my opinion.
Old 3/13/06, 9:26 AM
Community Guest
The owner is running a new circuit to the garage door opener only. Makes sense.
Allan
Old 3/13/06, 2:28 PM
Larry Ewens, C.M.R.I.C.'s Avatar
Larry Ewens, C.M.R.I.C. Larry Ewens, C.M.R.I.C. is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Rules 26-714(c) & 27-714(b)
Be supplied with a circuit used solely for the plug outlets located in the garage except that the garage lights and garage door openers may also be connected to this circuit.
Note: The garage plug outlets are not required to be protected with a G.F.I. type breaker.
Larry
Old 3/13/06, 3:11 PM
rmoore's Avatar
rmoore rmoore is offline
Please Note: rmoore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Allan,
Why not just reccomend an emergency release for the door?
http://www.genie-garage-opener.com/pargeremrelk.html
Under $20, easy to install, and that way he can get to his car even if the power goes out completely. Every "vault" garage with an opener should have one for that reason.
Old 3/13/06, 5:09 PM
Charles Buell's Avatar
Charles Buell Charles Buell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Richard---you the man! Excellent idea.
Old 3/13/06, 7:15 PM
Larry Kage, CMI Larry Kage, CMI is offline
Certified Master Inspector ®
Originally Posted by rmoore
Yes, very nice to know about...hade't seen one before.
Thanx
Old 3/13/06, 9:44 PM
Gary Schering, II's Avatar
Gary Schering, II Gary Schering, II is offline
Larry, I am under the understanding that because of the nature of garages, being prone to getting water from whatever, that G.F.C.I. would be recommended.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 3/13/06, 10:01 PM
That's what I recommend, too, Gary.
Maybe (the other) Larry is referring to a Canadian thing.
Old 3/13/06, 10:04 PM
Community Guest
In residential garages in Ontario it is not required by code, however in commercial applications the ESA Electrical Safety Authority will advise businesses to install them due to the likelyhood of snow melting off cars and washing of vehicles and the use of electrical equipment in service areas.
Allan Spisak
ACISS Home & Commercial Inspections
Old 3/16/06, 1:52 PM
What I quoted was from the code book. Code is a minimum and I always recommend GFCI,s in the garage. That way if you trip one you are already in the garage and not likely to get locked out.
Larry
Old 3/16/06, 6:01 PM
Raymond E. Wand Raymond E. Wand is offline
Are you referring to the ceiling plug as having to be GFCI or wall outlets?
I didn't think motor loads should be on GFCI because of nuisance trips?
Old 3/17/06, 8:12 PM
Vern Mitchinson, CCHI CMI's Avatar
Vern Mitchinson, CCHI CMI Vern Mitchinson, CCHI CMI is offline
Garage plug outlets Rules 26-702(20) & 26-704(10) 18th edition Canadian electrical code and Alberta amendments.
The following is a direct quote from the above code.
"At least one appliance plug outlet must be installed in each car space in a garage.
This outlet must:
Be duplex type Single type is not acceptable.
Be installed so that there is a plug outlet in each car space. To be truthful, the rule does not say "in" each car space, it says "for" each car space. However the intent seems to be that each plug outlet should be located in its own space.
Be supplied with a circuit used solely for the plug outlets located in the garage except that garage light outlets and garage door openers may also be connected to this circuit.
Note G.F.I. Protection - The garage plug outlets are not required to be protected with a G.F.I. type circuit breaker."
Carport plug outlets Rules 26-702(19)
Repeats the above and includes the following
"Be supplied with a circuit used solely for these outletslocated in a carport except that the carport lighting may also be supplied with this circuit."
I quoted the whole section exactly as it is written as there is some interpetition involved.
My interpretation is that GFI is not required for the door opener because plugs inside the garage do not have to be GFI but if the circuit is for a carport they must be GFI and on a seperate circuit.
To take it one step further I would interpert it that the garage circuits should also be on a seperate circuit from the exterior GFI plugs.
Commom sence also tells me not to have the door opener plugged in to a GFCI circuit that has exterior outlets and only one door. Looks to me like somebody was not thinking when they wired the door opener plug-in.
Vern Mitchinson_CCHI_CMI
Registar
AlbertaACHI
International Association of Certified Home Inspectors of Canada
Old 3/17/06, 8:17 PM
GFCIs do fail. I believe there is a new requirement or new design out or coming out that has a improved life span.
Old 3/17/06, 8:28 PM
Joseph Hagarty, CMI's Avatar
Joseph Hagarty, CMI Joseph Hagarty, CMI is offline
A Garage Door that is the Only Access to the Garage should have an Emergency Keyed Release to open the door in the event of a Power failure.
The Key with cable attaches to the release cable of the door operator
http://www.aaaremotes.com/emrelkit.html
Joe Hagarty
mrdryervent@gmail.com
Cell: (484) 883-7018
Boulder, Colorado
Certified CMI Master Inspector Instructor
PA NACHI Certified Inspector # 01102902
PA Licensed Radon Inspector # 2080
PA Licensed Pesticide Applicator # 700884
Delaware Licensed Home Inspector # H4-071
Installing GFCI in garage with no ground cyezza Electrical Inspections 53 11/30/07 6:05 PM
Evaporative cooler in garage chellickson Inspecting HVAC Systems 9 7/23/07 1:08 AM
Garage ceiling & door header Al Barb Interior Inspections 7 3/27/07 1:07 PM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 10:31 AM
UL Information about Testing of GFCIs jtedesco1 Electrical Inspections 0 2/5/06 5:38 PM
