Before You Start Repairing or Replacing Roof Finishes
All roofs need repair or replacement from time to time. Regular maintenance such as cleaning eavestroughs and drains can help prolong the life of your roof. Periodic roof inspections will help you spot developing problems before they cause costly damage to your home. The extent of the problem and age of the roof are key factors that can help you decide whether to do repairs or completely replace the roof finish.
Common Situations
Roofing comes in various materials, qualities and price ranges. Ongoing maintenance, suitable for the specific roof and material, is important and contributes to how the roof performs, when it needs repairs and when it needs replacement.
When you make decisions about roof work, there are many things to consider:
- Repair or replacement — The roof may have localized damage such as a few missing shingles, have widespread damage or have exceeded the life expectancy of the product.
- Structural problems — The roof may appear to sag in some areas because of insufficient strength or deterioration of framing or sheathing.
- Ice damming — There may be damage to the roofing material and structure due to build-up of ice during the winter.
- Flashing — Leaks may occur at the flashing.
- Moisture problems — excess moisture in the attic area can lead to deterioration of the roof structure.
- Roofing material — The roofing material may fail due to poor installation or may not be the proper type for the specific application.
- Safety and regulations — The extent of the project may require special equipment and training that should only be done by professionals. Working on roofs is dangerous and requires strict safety precautions.
Healthy Housing™
Renovating is an ideal time to make your house healthier for you, the community and the environment. When assessing your renovation project, be sure to consider the five essentials of Healthy Housing™.
House as a System
A house is much more than just four walls and a roof — it’s an interactive system made up of many components including the basic structure, heating, ventilation and air conditioning (HVAC) equipment, the external environment and the occupants. Each component influences the performance of the entire system. A renovation provides an opportunity to improve how your house performs.
Roofs play an important role in the system by shedding water before it can cause damage to building components.
Avoid Surprises
There are many different conditions that affect roof finishes. Taking the time to examine your needs and the options that are available is the right way to start to plan for your roof repair or replacement job. Here are some of the likely situations that people encounter. However, every situation is unique and you may need to hire a qualified professional to do a thorough investigation, find the problems and suggest the best solutions.
http://www.nachi.org/en/co/renoho/refash/images/ask.gif
- Are there damaged or missing individual shingles?
- Is there localized corrosion of metal roofing?
- Is there widespread damage to asphalt shingles such as missing gravel, curled or broken shingles?
- Are wood shingles rotting?
- Is the roofing material on flat roofs blistered, cracked or showing bare patches?
- Is there moss growth on the roof?
- Do you have the skills to properly assess the condition of the roof?
http://www.nachi.org/en/co/renoho/refash/images/consider.gif
- Replace individual shingles or sections of metal roofing.
- Repair shallow surface corrosion of metal roofing by priming and painting.
- Replace roofing material that has widespread damage or deterioration. All roofs have a limited life span.
- Seek advice from a roofing contractor or home inspector.
http://www.nachi.org/en/co/renoho/refash/images/andif.gif
- If damaged or worn out roofing is not repaired or replaced you will run the risk of having to replace rotten sheathing, fascia or structural members.
Structural problems
- Does the roof ridge appear straight?
- Does the roof surface appear to be flat without sags or dips?
- Does water pool in some areas of a flat roof?
- Consult a professional to determine if the roof structure is strong enough.
- Get professional help to determine ways to reinforce the structure.
- The problem will only get worse.
- An unusually heavy snow or ice load could break structural members.
Ice damming
- Does the roof have eave areas that are prone to ice build-up?
- Does the snow readily melt off of large areas of the roof?
- Is the attic warm through the winter?
- Improve insulation and air sealing to reduce heat loss and to limit warm air from leaking into the attic from the living space. Ice damming is most commonly caused when snow melts on a warm roof and then freezes at the colder roof edge.
- Install eave heater cables as a compromise solution, although these are not always effective.
- Ice damming will continue to cause water to back up under roof shingles and cause leaks.
- Ongoing leakage will wet the roof structure and insulation and can leak onto the ceiling areas causing rot, staining and structural deterioration.
- Shingle edges can break from built-up ice.
Flashing
- Are the various roof flashings in good condition?
- Is any caulking that has been used to seal flashing material damaged or missing?
- Is there damage to valley flashing material?
- Was the flashing installed properly?
- Repair or replace damaged or improperly installed flashing.
- Replace damaged or missing caulking.
- Consider using a trained professional to deal with damaged flashing. Flashing details can be complicated.
- Damaged or worn out flashing will allow water penetration.
- Ongoing leakage wets the roof structure and can leak onto the ceiling areas causing rot, staining and structural deterioration.
Moisture problems
- Is the roof framing or underside of sheathing damp or black?
- Are the ceiling finishes water stained?
- Is the attic insulation wet or damp?
- Check for roof leaks. Repair any leaks that you find. Attic moisture can be the result of a roof leak or condensation from warm moist air leaking into the attic from the living space.
- Air seal the ceiling area. Ensure that exhaust fans vent outside and not into the attic.
- Provide attic ventilation.
- Continued moisture accumulation will lead to rot and staining of the structure and finishes.
- Damp insulation will lose some of its insulating value.
- Mold may grow in the attic area.
Roofing material
- Is the current roofing material appropriate for the job? Would another material be a better choice?
- Is the roof structure capable of supporting the roof material (for example, clay tiles)?
- How old is the roofing material? Has it reached the expected life of the product? Would a different material be a better choice?
- What types of flashing materials are available?
- What are the special installation procedures for the various roofing choices?
- Research the available products. Find out which products quality builders and renovators are using in your area. Building supply companies, home shows contractors and the Internet are sources for information on products and application.
- Assess the roof structure, particularly if a heavy roofing material is being considered.
- Choose materials that are appropriate for your house, have an acceptable life expectancy and warranty.
- Review manufacturers’ recommendations for proper installation over existing roofs. Use a qualified installer, especially if special procedures are needed.
- Some roofing material may not be warranted for certain applications. For example, regular shingles cannot be used on roofs with a very low slope.
- The roof structure may not be able to support the load and could collapse from the weight of the heavy materials.
- The roofing material you choose may not last as long as you expect. This will result in poor performance and increased cost from another roofing job.
- Improperly installed materials may void the warranty.
- What safety equipment is required to provide protection from falls?
- What precautions are needed to protect the building and landscaping from construction debris?
- What permits are required?
- Are workers covered by worker’s compensation insurance? Does the contractor have a professional license if required by provincial law?
- As the homeowner, do you have liability insurance that will cover accidents due to the construction work?
- Ensure that the required safety protection is being used.
- Make sure to cover parts of the building and landscaping that are at risk from debris.
- Find out what building permits are required.
- Ask for proof that workers are covered by worker’s compensation insurance and that they have professional licenses where required. Get a written contract.
- Check with your insurance agent about adequate liability coverage.
- Someone could get hurt.
- Building officials may stop your project for non-compliance with codes and regulations.
- Penalties or fines may be imposed.
- Lack of insurance could lead to financial liability.
Rewards
- Timely roof repairs will protect the structure and finishes of your house from damage.
- A properly installed new roof will provide years of protection for your house.
Skills to Do the Job
At any phase of a roof project, even during the initial investigation, safety is a primary concern. Climbing up and down ladders and walking on roofs requires extreme care and attention, especially on steeper roof slopes. However, a homeowner with good fix-it skills and safety practices may be able to do some of the roofing work such as:
- Minor replacement or repairs.
- Repair of flashing or caulking.
- Stripping of existing roofing.
- Installation of new roofing.
Consider using a professional roofing company that has experience, proper equipment, professional licences where required, liability coverage and compensation insurance. Remember to obtain all necessary permits. Ensure that contractors working on your house use safe working practices and are covered by workers’ compensation. Staging and roof harnesses must be used to protect workers from falling. Protect yourself, your family and your home.
Use the Roof Assessment Worksheet to record the present condition, any problems in your roof, proposed upgrades and preliminary costing.
Roof Assessment WorksheetRoof dimensions Present condition / problemsProposed upgradesCostRoof materials
Curled or cracked shingles
Missing shingles
Moss growth
Leaks
Corrosion of metal flashings
Corrosion of metal roofing
Curled, split, loose or rotted wood shingles
Blisters, bare patches, curled edges on flat roofs
Damage to ventilators or roof vents
Other
Flashing:
Valleys
Eaves
Chimneys and Vents
Structure:
Sagging portions
Soft spots in roof deck
Other:
Costing Your Project
The cost of the roof repair or replacement will depend on the condition of the existing structure, local labour, material costs and the extent of the work to be done. A good budget checklist will help you to develop a realistic cost for the project before you start. Some of the items to include are:
- Repair of roof sheathing and fascia.
- Repair of roof structure.
- Repair of existing roofing.
- Repair of roof flashing.
- Cost of roofing materials.
- Permit costs.
- Safety equipment.
- Waste disposal.
