New CCPIA Article: Hiring Independent Contractors
A specialty consultant is typically hired to help an inspector tackle larger, more complex projects, or when the scope of work requires extensive knowledge or expertise about a particular system. The specialty consultant is considered an independent contractor, rather than a regular employee.
The following article reviews things an inspector should keep in mind when hiring an independent contractor.
You can read it here: Hiring Independent Contractors - Certified Commercial Property Inspectors Association
