I just started doing Radon testing in the NW Florida Panhandle last May, Im the only local company testing. I received a call from a builder that needs a radon inspection on a 40,000 square foot nursing home facility, 60 rooms. I have requested and waiting on more info about building so that I can put together a quote. I use Radalink Aircat monitors but I understand I would probably need to buy E-Perms or something similar to test in each of the 60 rooms. As I have never used anything other than Radalink, I do not know the procedures and costs for Pro-Lab, E-Perms and other devises. Also clueless as far as what type of report is provided (if any) with the different companies.
Was hoping to get some input from someone that has done commercial radon inspections like this and that may be able to provide input regarding quote and how to complete inspection. Thanks.
I use red Air-Chek kits for large buildings. You will not have to check every room, just every other one. If it is multiple floors, the kits would be in rooms that are “staggered”. That is on the first floor the kit is in a certain room, and the second floor kit is placed in a room that is staggered one room over from the first floor, etc. Records will be the largest expense, as you will need to document each room with the placement area, kit number, etc. Air Chek can assist you.
Many schools and hospitals bid out this procedure, and it is expensive for the testing person in time, documentation, placement, mailings, etc. I suggest allowing $125-150 per room. There should be state protocols that you must follow. You can also search the EPA radon site.
As this is a “Care Facility” I would be sure to use a reputable Laboratory such as EMSL or RTCA. I personally would never consider Pro-Lab (prior experiences).
Your state may also have specific protocols for Care Facilities, such as they would for Schools and such. A call or visit to your State Department of Health would be advisable.
Good luck.
