AskNACHI.org » Car mold in carpet/pad
Old 12/28/18, 3:04 PM
Unregistered
Guest
Posts: n/a
Default Car mold in carpet/pad
I live on Cape Cod and our car was damaged last March including windshield that was ultimately determined to be poorly installed and eventually leaked extensively onto floorboards and padding. This fall there was standing water on front seat floor boards and my car smells of strong chemical order. What is best way to test for mold and air quality? Repairs?
Old 12/28/18, 6:22 PM
Frank Rotte Frank Rotte is offline
Community Guest
Default Re: Car mold in carpet/pad
You could hire someone that does mold testing.
Certified Inspection Services, LLC
5521 Mission Road #1422, Bonsall, CA 92003
Check out the HG User Group on FB
ITC Certified Level I Thermographer
Old 12/28/18, 6:25 PM
Community Guest
Somebody like thishttps://molddoctors.net/
Old 12/28/18, 7:11 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Forget testing for anything..OK?
Remove all carpet and anything else that touched the water and dry it out...Or...
On the last one I did I had Stanley Steamer do most of the hard work for me..Yep!
I usually buy a few buckets of Damp Rid to help me dry it out after they do they're miracles......
That is just the beginning steps..
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 12/28/18, 7:19 PM
Roy D. Cooke, Sr's Avatar
Yep.
Remove pressure wash and dry worked for me. Than Fix leak .
Old 12/28/18, 7:58 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
I had a customer that had extremely elevated spore counts discovered from air sampling.
This was determined with the windows closed & the car was idling with the air conditioning on.
So..... true, you can clean, etc as most here have stated, but if the spores have left the infected surfaces there will be the possibility the AC system is now contaminated.
We're talking air quality here, besides the physical surface cleaning.
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
Old 1/1/19, 11:30 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
No kidding.
Zero reason to waste money on mold testing.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
