AskNACHI.org » Gas Water Heater
Old 9/17/18, 2:09 PM
NRCM
Guest
Posts: n/a
Default Gas Water Heater
Will an inspector warn his/her client about a gas water heater in a bathroom closet?
Old 9/17/18, 10:43 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
Default Re: Gas Water Heater
M2005.2 Prohibited locations.
Fuel-fired water heaters shall not be installed in a room used as a storage closet.
Water heaters located in a bedroom or bathroom shall be installed in a sealed enclosure so that combustion air will not be taken from the living space.
Installation of direct-vent water heaters within an enclosure is not required.
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
Old 9/18/18, 9:10 AM
Joshua L. Frederick Joshua L. Frederick is online now
Depends on the inspector you hired
http://aspecresidential.com
Defiance home inspector
Northwest Ohio home inspector
Old 9/20/18, 7:21 PM
William B. Ogletree's Avatar
William B. Ogletree William B. Ogletree is online now
Inspectors tend to focus on those things that are unsafe or unsound. If an inspector sees an water heater installation that is unsafe, he/she should report it. If it complies with accepted standards (i.e. is installed in accordance with manufacturer's recommendations), they may decide that reporting it is not necessary. Some inspectors will go beyond accepted standards and cite code, but risk citing a violation of code that a particular municipality might not adhere to.
Some will report such an installation out of an abundance of caution even if everything appears to be in order. Others may not.
William Bruce Ogletree
Ogletree Inspection Services
214-287-4630
www.ogletreehi.com
ogletreehi@gmail.com
