20 yr old home has major wet rot. Weep sceed plugged by massive concrete patio. Window installer halted 28 window installation because 21 of 28 window frames rotten, sagging. Removed 3/4" stucco with chicken wire and exposed 2"x8" verticle supports rotten at foundation and 2"x12" horizontal wood beams entirely rotten. 3 coat stucco is only thing holding up walls of house. Help! I need inspector to identify all walls containing moisture. I need a framer to cut away stucco, support walls and replace framing. I need fair, smart help for a 20 year problem l unknowingly bought 4 years ago:(
So… you never stated where you are located (city & state).
A location would be helpful unless you’re paying per diem.
