we have mold in the office i work in – i started not feeling well and found mold. pen/asp group was over 4000 in air test after mold was removed … one of the girls are pregnant and i’m concerned… nobody seems to be able to explain results
Contact your local OSHA field office. They will help you.
4000 is high. Seems like the job was not done correctly. Possibly no negative air filtration or HEPA vacuuming happened for starters…no? The number is way too high. Should be close to outdoor conditions. Or within a few hundred, at the very least. Pretty basic rule of thumb. AS/Pen numbers should be nearly gone.
How do you know what the rates are? What is the location?
