Old 7/17/18, 3:41 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
Certified Master Inspector
Default Advantages to thermal imaging?
Advantages:
Thermal imaging allows inspectors who are qualified to use thermal imaging cameras to document certain conditions and include them an inspection report in a manner that is visually interesting. The photos are colorful and can be somewhat fascinating, especially to the many members of the public unfamiliar with thermography. Photos not only allow viewers to see temperature- and moisture-related problems from a different perspective, but often, subject temperatures are posted as part of the image. So there are both marketing and communication advantages to including thermal images in an inspection report.
Under the right conditions, typically having to do with temperature differentials, thermal imaging may allow inspectors to more easily identify temperature-related problems like inadequate levels of thermal insulation, and moisture problems like roof or plumbing leaks where they might not be obvious to casual observation, sometimes because no staining has yet occurred and/or because they are in a high ceiling or upper part of a tall wall.
As inspectors develop increasing levels of expertise, they may find a significant amount of additional work as thermographers, as opposed to home inspectors. In some areas of North America, as thermographers, they may also have considerably less competition.
What else?
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/18/18, 11:50 AM
ROBERT YOUNG's Avatar
ROBERT YOUNG ROBERT YOUNG is online now
Default Re: Advantages to thermal imaging?
Nice post Kenton. Glad to see you posting in the thermal imaging section.
I have several observations to add.
Structural problems
Air leaks
Mechanical / electrical hot spots
Heat or Cooling Loss
Energy loss
Plumbing leaks
Defective or improperly installed seals and caulking deficiencies
Building defects
Settled or Missing or voids in insulation
Weather intrusion.
Robert Young's ​Montreal Home Inspection Services Inc.
Home Inspections & Building Inspection Services.
Covering on and off islands in greater Montreal and Laval. (514) 489-1887 or (514) 441-3732.
Our Motto: Putting Information Where You Need It Most, "In Your Hands."
https://montreal-home-inspection-services.com
Old 7/18/18, 10:11 PM
Mike Pagozalski, CMI Mike Pagozalski, CMI is offline
You never grab a warm beer ������
Mike Pagozalski
Mike@InspectTally.com
850-528-5585 (Cell)
FL Certified Home Inspector HI9519
FL Licensed Real Estate Broker BK3055789
FL Radon Measurement Technician R2530
ITC Level II Thermographer #150761
Exterior Design Institute (EIFS/Stucco) #FL131
Tallahasee's Home Inspection Team
Tallahassee Radon Testing
Tallahassee Home Inspector
Old 7/19/18, 6:56 AM
To further your question, advantages to thermal imaging?
Qualitatively or quantitatively identifying, by means of thermal energy emitted from an object.
An efficient, safer investigative method of/for measurement.
Decreasing personal liability.
Marketing power. Standing out, among your competitors.
Old 7/19/18, 7:06 PM
William B. Ogletree's Avatar
William B. Ogletree William B. Ogletree is offline
The first time I used my IR camera, I saw warm "trails" in some of the ceiling areas in a home that had rat droppings in the attic. This was Texas in the summer, and I opined that those were likely places where rodents had burrowed in the attic. When I see similar trails now I immediately suspect rodent infestation, and will re-check attic areas if no signs were found before.
So, I would add "Identify signs of possible rodent or other pest infestation" to the list.
William Bruce Ogletree
Ogletree Inspection Services
214-287-4630
www.ogletreehi.com
ogletreehi@gmail.com
Old 7/21/18, 11:21 AM
Erik Schmidt Erik Schmidt is offline
Fridge control is set to coldest, imager says fridge temp is 40 F, "recommend replacing refrigerator"
A quick way to verify oven elements are working without waiting for the glow or burning your fingers.
Clients are impressed after they ask "how much did it cost you"
Entertaining clients kiddies
Checking out if clients are hot
Looking in the bushes for burglars at night
Discovering your 1954 Vincent Comet is running too hot.
Advantages to thermal imaging?-june13-jpg
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 7/22/18, 1:45 PM
Ian W. Mayer, CMI's Avatar
Ian W. Mayer, CMI Ian W. Mayer, CMI is online now
Certified Master Inspector ®
I inspected a house a few months back. My thermal imaging camera noted a cold spot under the master bathroom. I confirmed a small wet spot with a moister meter.
All of this is in my report.
Well, the seller has a contractor come over, he can't find the wet spot, tells everyone who will listen "that home inspector doesn't know what he's talking about, his equipment must be broken...."
Buyer moves in. Continues to have issues. At some point, someone opens up a wall in the master bathroom, and there is wood rot in the wall and evidence was found that implies the seller knew about it.
Now there is a discussion of a lawsuit but said lawsuit does not involve me.
Thermal Imaging has the potential to document evidence that will protect the HI from legal disputes.
Old 7/23/18, 3:41 AM
Dave Fetty, CMI's Avatar
Dave Fetty, CMI Dave Fetty, CMI is online now
I found a slow roof leak last week that I or anyone could never have found without IR.
Dave Fetty Certified Master Inspector
Florida Home Inspection And Property Services LLC
www.FHIAPS.COM
www.NaplesBestInspector.com
www.FortMyersInspector.com
Naples, Marco Island, Ft. Myers, Bonita Springs, Estero, Cape Coral
Dfetty@FHIAPS.COM
http://https://www.facebook.com/pages/Flori...2450912?ref=hl
Florida Radon Measurement Technician R2547
(239)339-7380
Old 7/24/18, 11:45 PM
Because you have rain!
Here, every time I call out a roof defect, an agent shouts "but there aren't any leaks". Yeah, it's summer in Southern California. It hasn't rained in months, and won't rain again for many more months. Of course, there aren't any active leaks!
But I digress.
Old 7/25/18, 5:22 AM
We went for months after Irma, with no rain, so thankful that it has started raining again.
www.FHIAPS.COM
Dfetty@FHIAPS.COM
(239)339-7380
Old 11/27/18, 3:47 AM
Mitchel Brooks's Avatar
Mitchel Brooks Mitchel Brooks is offline
Best use for thermal 😂
