Hello all
had an interesting inquiry today about thermal imaging.
it was asked if thermal imaging could be used to scan an area where a house had burnt down to see if the debris had been buried or cleaned away?
the ground had been leveled,
thought I would inquire with the group, to see what ya’ll had to say bout that, lol
That’s what GPR is for: http://www.geophysical.com/whatisgpr.htm
If the temp of the ground has reached equilibrium in my opinion IR will do you no good.
Correct.
You may be able to see where the soil was disturbed due to density, but nothing below grade will change the emissivity or specific heat of the soil above.
You can also use a GEMS scanner (treasure hunters top end scanner). Cheaper than GPR services.
