Old 6/10/18, 7:04 PM
William B. Ogletree's Avatar
William B. Ogletree William B. Ogletree is online now
Default Found with thermal - show us yours!
I thought it might be fun and helpful for us to share IR photos that led us to discover and/or confirm problems in a home. Ideally, each photo should show some kind of temperature anomaly, the hypothetical cause, and how that hypothesis was proven, or as importantly, dis-proven, and how it was covered in the report.
I'll start with this one from a recent inspection.
These photos show with what appear to me to be "trails" in the thermal signature. Having seen this pattern in attics that had rodent droppings, my hypothesis was that there was a past or present rodent infestation.
In the attic I found the areas above had insulation packed down in "trails", consistent with the patterns found when rodents have been moving about. I also observed a few rodent pellets. I did not excavate.
All that was enough for me to state that there was a past or present rodent infestation, but the tenant overheard me talking to the buyer about what I had found and he piped up "yeah, I hear things moving around up there, but I've never seen anything". That pretty well cinched it.
Final determination was, based on thermal patterns, packed-down insulation, observed rodent feces, and statements by the tenant, that there is an active rodent infestation and a professional exterminator needs to be called in.
Found with thermal-flir0473-jpg   Found with thermal-flir0466-jpg   Found with thermal-flir0468-jpg
William Bruce Ogletree
Ogletree Inspection Services
214-287-4630
www.ogletreehi.com
ogletreehi@gmail.com
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/10/18, 7:59 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Default Re: Found with thermal
Why would the trials be hot?
I don't think what you are seeing are from rodents..
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 6/10/18, 8:34 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Where are the associated digital pics?
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
www.LeadingEdgeInspectionServices.com
Old 6/10/18, 8:43 PM
Jeffrey Moore, AZ#49250 Jeffrey Moore, AZ#49250 is offline
Trails would show as an elevated/cooler temperature (depending on season) due to decrease/disruption in insulation allowing attic temp to show in house
Jeff Moore
www.quantumhomeinspections.com
Flir (ITC) Level II Thermographer
Mesa, AZ
(602)448-2926
Old 6/11/18, 9:11 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Compressed insulation (observed and verified) increased density which increases thermal conductance. It is summertime in Texas!
Hay Jeff! Long time since we worked together! Hope all is well in AZ.
Good to see your still at it.
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
Old 6/11/18, 10:07 AM
Good job, with a good follow-up!
This is how you do it folks. The Thermal Camera is only as good as your investigative technique.
Seeing a blue spot, using a moisture meter, and calling it water is NOT good technique. We see this all the time. The blue spot may not be the result of a water leak. It could be the source. Do you know how to tell?
This scan is a 1st floor den ceiling. Plumbing fixtures located on the 2nd floor above. No moisture staining visible on the ceiling. No access to the ceiling from above. Pin moisture meter indicates elevated moisture levels.
Is this a water leak and what is the source that requires repair? This will require invasive access so you better be right...
Do you trust your moisture meter?
How can you verify the moisture source before you open the ceiling?
Found with thermal-ir_2710-jpg
BPI# 5015804
Old 6/11/18, 10:44 PM
Jeffrey's answer would be mine: Trails would show as an elevated/cooler temperature (depending on season) due to decrease/disruption in insulation allowing attic temp to show in house.
Heat in the attic transmits more easily through packed-down insulation than non-compressed insulation. When rodents burrow into the insulation, they create voids which allows hot air to come in contact with the ceiling drywall. If not rodents, then what? I can think of nothing else that would create the trails I am seeing.
Also, every time I have seen these patterns, I have found other evidence of rodent infestation.
214-287-4630
www.ogletreehi.com
Old 6/11/18, 10:56 PM
I use a pin and pinless meter, depending on the situation. Testing them on known dry and moist samples gives me confidence they are not misleading me.
In trapped ceilings, invasion is really the only way to verify the source. Fortunately, borescopes can cut down on the level of invasiveness, but that's for someone else to mess with.
Great responses from everyone. IR comes with a lot of challenges, and I need to constantly question my assumptions lest I fall into a self-made trap.
Hoping to see examples from others.
214-287-4630
www.ogletreehi.com
Old 6/13/18, 5:23 PM
Charley L. Bottger's Avatar
William here is one just for you found this morning on a 5K home. I don't leave my camera in the case on a home inspection. How would I know if that knife blade was loose by looking at it. I guess if my name was JJ I could of touched it with my tongue
Found with thermal-dscn8261-jpg   Found with thermal-ir_21765-jpg   Found with thermal-ir_21766-jpg
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 6/13/18, 5:34 PM
Good stuff, Charley. Thanks!
214-287-4630
www.ogletreehi.com
