Old 1/3/18, 12:17 PM
John Harrison, CMI's Avatar
John Harrison, CMI John Harrison, CMI is offline
Certified Master Inspector
Default Frozen water lines
Anyone use Thermal to find the frozen blockage in a water line?
Would this be effective?
<a href=http://www.bluffshomeinspection.com target=_blank>http://www.bluffshomeinspection.com</a>
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Council Bluffs Home Inspector
Iowa Home Inspector Council Bluffs - Facebook
Active Rain Member
Old 1/3/18, 12:35 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Retired Member
Default Re: Frozen water lines
Water and Ice can both exist at 32F.
It is about the Btu removal to accomplish a change of state.
How is a thermal camera going to measure Btu transfer?
If you can get some warmer water moving through the pipe you will see the ice. But by then the problem is solved. Moving water will remove the ice block.
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
