Old 4/11/18, 8:39 AM
Paul Lesieur, CMI's Avatar
Paul Lesieur, CMI Paul Lesieur, CMI is offline
Default Fun with thermal
I just cleared out some old pictures I took from when I first got my E8
Do I need brakes?
Is there moisture behind that crown molding?
Fun with thermal-flir0152-jpg   Fun with thermal-flir0151-jpg   Fun with thermal-flir0236-jpg   Fun with thermal-flir0235-jpg
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/11/18, 8:49 AM
Jim Coleman's Avatar
Jim Coleman Jim Coleman is online now
Default Re: Fun with thermal
Do I need brakes?
Brakes most likely showing heat from use. Definitely looks like moisture behind the molding, but I'm not certified in thermal yet, so....
I'm sure I will be imaging everything when I get into thermal
Old 4/11/18, 9:10 AM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Certified Master Inspector ®
Possible moisture at the molding, but need to be checked with a moisture meter to confirm.
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Old 4/11/18, 1:18 PM
Roy, there was moisture there, I used my finger instead of my moisture meter so that was an easy one.
Brakes were fine.
I also found pictures of my pointing the camera at my wife's (ahem).
I'm a bit more serious now. Used my camera yesterday to find cold spots on an exterior wall, turned out to be sprinklers in the grill area on the covered balcony.
Thermal cameras do so much and there is so much to learn just to use one properly.
Old 4/11/18, 3:03 PM
The old finger method I use that all the time. LOL
The learning with IR is indefinite.
Just when you think you got it figured out. The camera will prove you wrong.
#1st Pro Inspection
Old 4/12/18, 12:10 PM
Frank Rotte's Avatar
Frank Rotte Frank Rotte is online now
I like to use it on the job. It justifies my higher rate. YouTube
Certified Inspection Services, LLC
5521 Mission Road #1422, Bonsall, CA 92003
San Diego Home Inspection
Like me on Facebook
Award Winning Sample Report
Check out my blog
My Privacy Policy
Temecula Home Inspection
Check out the HG User Group on FB
ITC Certified Level I Thermographer
Old 4/12/18, 12:11 PM
I do have ta-ta pictures. But it was for science.
Like me on Facebook
Check out my blog
My Privacy Policy
Old 4/13/18, 10:40 AM
Steve Nadeau's Avatar
Steve Nadeau Steve Nadeau is online now
Ha! That's not where my girl was glowing white (using the iron filter) - I like science too!
Old 4/16/18, 3:34 PM
Robert Dunn Robert Dunn is online now
I can't wait to get my thermal camera, besides being a great tool. It looks like a lot of fun, a bit like xray vision!
Old 4/16/18, 3:47 PM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
Don't even say that in kidding!
Clarksville - Nashville Home Inspector Lic#40 (Retired)
BPI# 5015804
Old 4/16/18, 5:44 PM
Yes it is I take mine in the mall whenever I go LOL
I have some great shots
#1st Pro Inspection
Old 4/17/18, 8:33 AM
I admit I did use my camera inappropriately, but as someone said, "it was for science".
