Old 10/6/18, 7:50 AM
Chuck Evans's Avatar
Certified Master Inspector ®
Default For those who do infrared, do you
do this
For those who do infrared, do you-tubtest-jpg
to find this?
For those who do infrared, do you-ir_13383-jpg
If not, you should consider it.
For those who do infrared, do you-tubtest-jpg   For those who do infrared, do you-ir_13383-jpg
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/6/18, 8:26 AM
Marcel Gratton, CMI's Avatar
Marcel Gratton, CMI Marcel Gratton, CMI is offline
Default Re: For those who do infrared, do you
•Bath tub and basin overflow connections are not included in the scope of the inspection and are not tested.
On The Level Inspection
Gatineau, Québec
Old 10/6/18, 9:12 AM
Frank Rotte Frank Rotte is offline
Community Guest
I specifically disclaim the overflow.
Certified Inspection Services, LLC
5521 Mission Road #1422, Bonsall, CA 92003
Check out the HG User Group on FB
ITC Certified Level I Thermographer
Old 10/6/18, 6:24 PM
William B. Ogletree's Avatar
William B. Ogletree William B. Ogletree is offline
Boy, that's a tough one. I used to be a proponent of testing overflows, but conversations at this forum changed my mind.
It's hard to decide whether or not the technique depicted would fall withing "normal use". There are many who are of the opinion that tub and sink overflow testing is beyond the scope, and given the potential for consternation (at best) and legal action (at worst) on the part of a seller for causing moisture damage, I must honestly say that I would tend to shy away from it.
An exception might be if I was doing a one-year warranty inspection, but even then I would need some kind of written release.
William Bruce Ogletree
Ogletree Inspection Services
214-287-4630
www.ogletreehi.com
ogletreehi@gmail.com
Old 10/6/18, 7:30 PM
Larry Kage, CMI's Avatar
Larry Kage, CMI Larry Kage, CMI is offline
Years ago, when I was doing IR imaging with my B400 w/temp upgrade, an image similar to Chuck's below may not show any visible signs of water damage at all, to the naked eye. YMMV, especially depending on imager.
For those who do infrared, do you-1-jpg
Awards Committee Officer
SUBMIT YOUR AWARD NOMINATIONS HERE:
http://co.nachi.org/inachiawards/
The InterNACHI Awards Committee is the final authority of the issuance of any award the committee offers and any rules interpretation updates.
Larry Kage, CMI Lifetime Member
State Licensed Builder since 1973
InterNACHI Lifetime Member
~retired~
The above post represents my personal opinion.
Old 10/6/18, 8:13 PM
Ten seconds will give you something you can see with infrared, probably not with the naked eye. This one was not visible.
If the drain leaks, it's going to leak. It can leak a little while you're there or a lot after your client moves in and the kids fill the tub. If you're walking around the house with an infrared imager, you're already well beyond the SOP. I never want my clients to wonder why they bothered to hire me. My infrared thermography inspections are not part of the HI SOP. when I get hired to perform a thermography inspection, this is in scope.
This one happened to be a $2M custom. Both the builder and the buyer were thrilled to learn about this before they got all their furnishings and possessions in there.
Houston, TX
Old 10/6/18, 8:19 PM
Exactly...or less time...depending on the imager quality.
~retired~
Old 10/6/18, 8:29 PM
Today was a slightly different variation on the water theme. This might be out of scope too.
For those who do infrared, do you-pa060057-medium-jpeg
Houston, TX
Old 10/6/18, 8:41 PM
Dave Fetty, CMI's Avatar
Dave Fetty, CMI Dave Fetty, CMI is online now
I started doing that a couple years ago when you first posted about this topic. Haven't found a bleeder.... yet
Dave Fetty Certified Master Inspector
Florida Home Inspection And Property Services LLC
www.FHIAPS.COM
www.NaplesBestInspector.com
www.FortMyersInspector.com
Naples, Marco Island, Ft. Myers, Bonita Springs, Estero, Cape Coral
Dfetty@FHIAPS.COM
http://https://www.facebook.com/pages/Flori...2450912?ref=hl
Florida Radon Measurement Technician R2547
(239)339-7380
Old 10/9/18, 1:24 PM
ROBERT YOUNG's Avatar
ROBERT YOUNG ROBERT YOUNG is online now
Nice tip Chuck. I would consider this when ceilings or walls are damaged below or other visible systems are apparent within the drain location.
Typically/usually, my reports disclaim overflow drains.
Thanks.
Robert Young's ​
Montreal Home Inspection Services Inc.
Home Inspections & Building Inspection Services. Covering on and off islands in greater Montreal and Laval. (514) 489-1887 or (514) 441-3732.
Our Motto: Putting Information Where You Need It Most, "In Your Hands."
https://montreal-home-inspection-services.com
https://www.nachi.org/forum/f13/rece...-cooke-106880/
