This was a much needed class . except and this is pretty much for us in the south is the importance of insuring the wind / hurricane classification. In most cases they do not meet the guidelines and seller should provide all information concerning certifications or inspector need to refer to and expert.
D. Fackler
Riverview Fl. and yes I’m still around
Is this available in a printable format or PDF file?
Andrew Fox
General Manager
The BrickKicker
As always, thank’s Ben!
Regards.
Robert Young
Thanks Ben!
Thanks to Mike Bitterman of SNS home Inspections LLC and Kevin M. Leonard of The Ohio Home Inspections Company for the inspection images for the article www.nachi.org/inspect-sklight-shaft-wall-insulation.htm
This article gets longer and longer.
This is a variable cornucopia of proper skylight insulation techniques.
Unfortunately, all the “Your The King Mate” designations are in use.
As soon as one comes available, it’s all yours for a measured amount of time.
