Old 12/14/18, 11:24 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is offline
Certified Master Inspector
Default I need a killer photo of water in a flat roof...
...for the commercial roof course. Preferably something really clear and making it obvious that under the right conditions IR can be a big help in identifying water in a roof system. Two photos of the same roof, one IR and one conventional photo would be great.
Photo credit will be given.
Please email to kenton@internachi.org
Kenton Shepard, CMI Inspector/Instructor
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/14/18, 11:47 PM
Chuck Evans's Avatar
Certified Master Inspector ®
Default Re: I need a killer photo of water in a flat roof...
The types of patterns you see are dependent on the type of insulation.
You have my permission to use these as you like.
I need a killer photo of water in a flat roof...-ir_1142-13-jpg   I need a killer photo of water in a flat roof...-commercial_roof_6-4-jpg
Chuck Evans (TREC #7657)
The Woodlands Home Inspections
Magnolia TX Home Inspections & Thermography
Houston, TX
_______________________
Awards Committee Member
Old 12/15/18, 10:52 AM
Charley L. Bottger's Avatar
Here are some images of two different type roof material one with rock and one with out. You can clearly see the substrate hold down tabs
I need a killer photo of water in a flat roof...-dscn5910-jpg   I need a killer photo of water in a flat roof...-ir_21364-jpg   I need a killer photo of water in a flat roof...-ir_5352-jpg   I need a killer photo of water in a flat roof...-ir_5315-jpg   I need a killer photo of water in a flat roof...-ir_5314-jpg
http://www.oklahomathermalinfraredimaging.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
55 years in the Trades
Okla State License # 130
580-268-3340
Old 12/15/18, 11:11 AM
Here is a couple more with a elevated view this was on a brand new roof.
You may copy any I have posted
I need a killer photo of water in a flat roof...-dscf2221-jpg   I need a killer photo of water in a flat roof...-dscf2216-jpg   I need a killer photo of water in a flat roof...-ir_10252-jpg   I need a killer photo of water in a flat roof...-ir_10256-jpg
580-268-3340
