Green Building Inspections Contains discussions about green buildings and specific concerns when inspecting them.
Old 10/19/13, 1:45 PM
KEVIN WOOD, CMI KEVIN WOOD, CMI is offline
Banned
Please Note: kwood is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default New way retaining wall
http://www.intelligentbuildingtoday....leantech-open/
Company that uses recycled tyres in construction wins at CleanTech Open
16 Oct 13 | Author Saleha Riaz | New Products & Services
  • inShare
As reported earlier, the CleanTech Open is a world wide competition and business accelerator for businesses in one of 8 categories of sustainable enterprises. The mission of the CleanTech Open is to find, fund, and foster entrepreneurs with big ideas that address today’s most urgent energy, environmental, and economic challenges. ArmaTerra Georeinforcing of Reno, NV became the Western Region Winner in the Green Building category in this 6 month program.
We are very happy and proud of this recognition. It is quite an achievement for us as we have been working on gaining more traction with the investor community,” said CEO, Sergio Nevel. “This award coupled with a recently issued patent will help to take us the rest of the way to commercialization.”
Michael Merrill, ArmaTerra’s Chief Technology Officer started working this idea several years ago. In 2009, he joined forces with Sergio Nevel to create a company to take his ideas to market. Since then, they formed ArmaTerra® Georeinforcing and began patenting Michael’s innovations. When retaining walls, slopes and levees are reinforced today, the state of the art is to use polymer or metal georeinforcing elements to strengthen the earth that is being retained and reinforced. ArmaTerra’s technology instead uses recycled tire treads that are uniquely configured and fastened using a proprietary non-corrosive fastening system.
Current products are less favorable than GeoTire® products because polymer based products are not as strong as metal and, therefore, less desirable for robust applications such as for use in highway construction. Metal is stronger and more widely used for such applications but presents other problems like corrosiveness which sometimes results in a reduced life and a high cost of trucking in special backfill when native soils amplify this problem.
GeoTire® provides the strength and non-corrosiveness because it is a product made with metal and coated with a synthetic cover. Tire treads are made with steel belting and are coated with a synthetic blend made of vulcanized rubber and latex. ArmaTerra’s process ensures that the metal is not exposed and the fastening system used to link as many treads as are needed for each job is made of a very strong non-corrosive nylon.
Of the 300 million waste tires generated in the U.S. each year, only 50% are beneficially repurposed. Approximately 40% are used as fuel and burned and 10% still end up in land fills. GeoTire® products put these tires to a higher and better use. They are also longer lasting, require no special backfill, are very strong and can save many private and public dollars when accepted and used in the construction of highways, rail systems, bridge abutments, marine applications, temporary and permanent retaining walls, mining and industrial roads/ramps, slope reinforcing, and in retrofitting existing earthen levees.
“We believe that our company and our products are perfectly poised to help America rebuild its infrastructure in a profitable, green, and sustainable way,” says Nevel. “This recognition goes a long way in acknowledging our vision and the clarity of our mission.”
ArmaTerra® Georeinforcing is an early stage start up Nevada Corporation that is currently seeking demonstration projects as well as investment from accredited investors in order to scale up operations.
Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/19/13, 6:19 PM
John donnelly101 John donnelly101 is offline
Please Note: John donnelly101 is a non-member guest and is in no way affiliated with InterNACHI or its members.
That's great news in the more Eco savvy states. I was stopped by the DEP of doing such a thing and could have been fined heavily if I didn't take the tyre s off site and dispose of in a registered recycle plant.
Old 11/11/13, 8:32 AM
Rony Mikal Rony Mikal is offline
Please Note: Rony Mikal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: New way retaining wall
Thanks for the insight and the advice. I would imagine new way of retaining walls would last longer with the proper drainage system behind them and if they were located in a shady area, regularly attacked by sprinklers or other forms of moisture.
Old 10/3/16, 3:51 PM
Jonah Reynolds Jonah Reynolds is offline
Please Note: Jonah Reynolds is a non-member guest and is in no way affiliated with InterNACHI or its members.
Earthship Tire Retaining Walls
https://earthship360.com/retaining-walls/
The same method for building structural walls in buildings can be applied when building retaining walls made with rammed earth encased in steel-belted rubber. Depending on the load the retaining wall is ‘retaining’, the batter and other adjustments should be considered.
Some tire retaining walls have been built up to 25 ft. high. Tires make an inexpensive solution that requires no concrete, wood or steel. The proper construction of a tire retaining wall involves filling the tires with dirt that’s compacted with a sledgehammer or a pneumatic tamper. We call this process “pounding the tires.” First, you place the tire on a level grade, then pound it, checking it for level. Always pound a tire in place. A 15-in. tire will take nearly 300 lb. of earth.
Old 3/12/17, 4:38 AM
Sharon D. Nicholson Pena Sharon D. Nicholson Pena is offline
Do you have tiebacks or deadmen involved
Sharon Nicholson-Pena
President
Nicholson Pena LLC
Roofing or Home Inspection
1017 Platte Dr
Fort Lupton CO, 80621
303-502-3322
www.nicholsonpena.com
Welcome to Your Happy Home
knowing is half the battle
Old 10/2/17, 8:24 AM
ROBERT YOUNG's Avatar
ROBERT YOUNG ROBERT YOUNG is offline
Gabions. Aggrogate and wire system. Old Engineering application to retain soil.
Attachment 197591
Robert Young's Montreal Home Inspection Services Inc
Call (514) 489-1887 or (514) 441-3732
From the foundation to the roof, the basement to the attic. A detailed home inspection services every time!
Our Motto: Putting information where you need it most, "In Your Hands."
https://montreal-home-inspection services.com
https://home-inspectionservices.com
Basement vapor barrier jfrederick Interior Inspections 11 4/3/16 1:28 PM
Failing basement wall, structural engineering group says john bubber Structural Inspections 1 7/29/13 6:08 AM
Advice regarding structure of small retaining wall Don Alexander Exterior Inspections 6 5/21/12 11:11 PM
Major retaining wall issues dvalley Exterior Inspections 21 8/24/09 7:47 AM
Moisture Management mcyr Exterior Inspections 15 9/8/08 1:11 PM
