Seller Inspections & MoveInCertified Contains discussions about seller inspections and the MoveInCertified program.
Old 4/25/14, 8:54 AM
Jeffrey Belfus Jeffrey Belfus is offline
Default Pre Listing Consultations
I have been reading about some inspectors doing these Pre Listing Consultations. They say it is just an hour walk through of the property with the seller. My question is, In an hour do you access the roof, crawl space and attic? In my opinion these are three of the most important spots to check. And usually take me over an hour to do. It seems like a lot of areas of the home would not be checked in an hour walk thru.
Jeffrey Belfus
Precision Property Inspections LLC
JBelfusPPI@gmail.com
215-432-1649
www.turnersvillehomeinspections.com
Need a home inspection in New Mexico? Check out InterNACHI's listing of New Mexico certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/25/14, 9:05 AM
Derek Grace's Avatar
Derek Grace Derek Grace is offline
It all depends what the seller wants. If he wants a full inspection with report then price as such...
GoldenEye Home Inspections LLC
http://goldeneyehomeinspections.com/
gracey29@hotmail.com
Select your club and trust your swing
Old 4/25/14, 9:12 AM
Default Re: Pre Listing Consultations
Most states define what a home inspection is ... and require that a home inspection be accompanied by a written report.
Some inspectors are performing home inspections, by definition ... but are mistakenly calling them "walk throughs" etc ... and are not writing reports. This is not advisable since the home inspector is taking on the complete risk of being held accountable by his client and his state for missed defects resulting from a violation of his state law.
A genuine "walk through" does not entail having the inspector look at anything on his own ... but simply walk through a home with a client and answer questions about things a client points out to inquire about. When the inspector takes it upon himself to explore and, in that process, observes and comments on more than two systems ... he is performing a home inspection and the laws kick in.
Another consideration is the requirement of the E&O provider.
Calling a home inspection a "walk through" does not necessarily change the rules.
Old 4/25/14, 9:50 AM
I was reading in the seller inspections and move in certified forum that inspectors are doing these consultations. It seems like a huge liability to give 1 hour with no report or no pictures. Just wanted to see how many people are doing these Consultations.
Jeffrey Belfus
215-432-1649
Old 4/25/14, 10:59 AM
I've read some of those comments, as well. I agree with you.
Old 5/2/14, 8:22 AM
Stuart Harrison, P. Eng. Stuart Harrison, P. Eng. is offline
I offer consultations but the inspection process is the same (whole home, top to bottom)--where I differ from a traditional inspection is by letting the client (seller) take the notes. We then sit down at the end and compare notes for items that need attention and items that can left to the buyer to sort out.
The conversation we have is that every inspector (and buyer) is different but if I have done my job correctly, I have identified the issues that tend to go back for amendments. Do I care if I miss a loose outlet - no because buyer's don't renegotiate and ask concessions from the seller for trivial items. If I miss a bad furnace, roof, A/C, leaky basement, unsafe items etc.--I deserve to be sued.
WWW.CAPSTONEPROPERTY.CA
STU@CAPSTONEPROPERTY.CA
905-407-2289
It is better to be thought a fool, than to whip out your keyboard and remove all doubt...
Old 5/2/14, 11:01 AM
David A. Andersen, TN HI# 40's Avatar
David A. Andersen, TN HI# 40 David A. Andersen, TN HI# 40 is offline
You do it the same as any inspection (unless the Seller contracts with you otherwise).
You simply write the report and a different perspective (the sellers versus the buyers).
The only thing that makes it any shorter is that the seller only wants to know about the major things it must be fixed according to the real estate contract.
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 12/19/14, 7:58 PM
Philippe G. Heller's Avatar
Philippe G. Heller Philippe G. Heller is offline
It also has a lot to do with your written agreement with the client. The purpose is to identify items that would likely come up on the buyer's inspection report. Most of the items turn out to be maintenance items. It is obviously not as exhaustive as a full inspection and it is not intended to be. That's why it costs far less than a full inspection. Eliminating pictures and the report reduces an amazing amount of time. Also, the seller knows his house, so he doesn't need as much "show and tell" as a buyer.
Old 12/19/14, 8:33 PM
Mike Auger's Avatar
Mike Auger Mike Auger is offline
Certified Master Inspector ®
I do not do a "short version walk through" any more. They always seem to turn into something very close to the full thing anyway. I do pre list inspections, it is the same inspection I'd do for a buyer.
Mike Auger, CMI
RI Reg. # 32856
RI Radon Lic. # RMC-142 RMB-096
(401) 578-4878
A U.S.A.F. Veteran Owned Company
Free Listing for Infrared Certified Thermographers. gromicko Thermal Imaging, Infrared Cameras & Energy Audits 10 3/31/10 9:01 PM
looking for actual data on pre listing inspection success wmarston Canadian Home Inspectors 9 5/19/08 5:23 PM
Keller Williams REALTOR speaks on Listing Inspections in Greenville, SC on April 11. gromicko Miscellaneous Discussion for Inspectors 5 3/25/08 6:20 PM
List Your Business For Free jbowman Miscellaneous Discussion for Inspectors 17 8/13/06 1:29 PM
