Use this thread to discuss the entry New article on electric fence inspection at the InterNACHI Blog
As stated in the article, this is incorrect:*
"*Inspectors can tell if a fence is working by touching the metal end of a long screwdriver to the conductor while holding the plastic, insulated end. An active fence should create a visible, audible arc."
Just pee on it…you’ll know in a second if it is working.
Care to expand on that?
