Home Inspection Blogs Discuss the latest entries from the InterNACHI Blog and other prominent home inspection blogs.
Old 8/14/18, 11:48 AM
Luisa Nacpil Luisa Nacpil is offline
Community Guest
Please Note: lnacpil is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default The Right Roofing Tools for your Commercial Roofing Maintenance
Hi everyone! I just want to post this article to give newbies guides and tips about the Roofing Tools for your Commercial Roofing Maintenance! Enjoy reading!
Signs You Need To See A Roofer
Although a roof is a simple part of your building, it provides more benefits than you know. Good maintenance extends the life of your roof. It is also interesting to note that a well-designed roof can also play an important role in keeping your roof in tip-top shape. Don't wait for your roof to show serious damage. Call a roofing specialist when you see signs of wear and tear.
● Flashing spaces: Flashing expands over time due to harsh weather conditions. The damage can pose a threat to your roofing, especially during heavy rains.
● Accumulation of water: When there is excess standing water, the damage can snowball into more serious defects such as leaks. The moisture creates a dangerous impact on your beams, weakening the support of your roof.
● Bubbles: Too much heat and moisture leave bubbles in your roof, making them susceptible to wind or leak damage.
Evaluating Your Commercial Roof
If you see signs of damage in your commercial building's roof, they can be due to extreme heat, rain, ice, wind, aging, improper design, pollution and natural disasters. Professional roofers perform assessments to understand your roofing systems. The contractors keep records of modifications. These records will cover time and labor costs, repair materials, emergency repairs, building damage repairs. The record serves as a guide to finding out about the problem areas that require immediate solution.
Since it's not easy to maintain a roof, building owners will resort to minimum maintenance without realizing its implications. Owners who understand the importance of commercial roof maintenance, choose a proactive maintenance plan to know the roof repair project to prioritize. After the inspection, the contractor will make recommendations on fixing the problem.
Commercial Roof Maintenance
Professional roofers outline a plan so you will know what to expect from a roof maintenance program.
● Roof Inspection: The initial step of the program is to conduct an inspection to spot existing problems. The contractors or commercial facility managers perform an inspection twice a year to identify problems. The contractors check if there are any signs of damage which could get worse during severe weather conditions. They will also inspect the blockage of drains and flashing gaps.
● Roof Repairs: Some contractors schedule routine repairs the same day as the roof inspection. In most cases, roofers schedule repairs in advance. The purpose of repairs is to ensure that small roof problems will not turn into a serious liability, which affects your building's structure safety. Although these are quick fixes, they are important tasks because they serve as additional layers of roof protection.
These days, most roofing tools use new technologies to make it easier for professional roofers to perform routine maintenance. Entrust your commercial roofing maintenance to a company that understands the proper way of maintaining a commercial roof.
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/15/18, 8:42 PM
Marc A. Goldenberg's Avatar
Marc A. Goldenberg Marc A. Goldenberg is offline
Default Re: The Right Roofing Tools for your Commercial Roofing Maintenance
SPAM
http://www.alltropic.com
Awards Committee Member
The InterNACHI Awards Committee is the final
authority of issuance of any award the committee offers.
Old 12/2/18, 2:52 AM
Mitchel Brooks's Avatar
Mitchel Brooks Mitchel Brooks is offline
Cool
