Texas/TPREIA Home Inspectors This is a place for Texas InterNACHI inspectors to discuss Texas home inspection topics. Become a home inspector in Texas
Old 7/30/17, 1:40 PM
Kenton Shepard, CMI's Avatar
Kenton Shepard, CMI Kenton Shepard, CMI is online now
Certified Master Inspector
Default Texas reporting requirements?
Although I know they're different from many states, I'm not really familiar with the Texas requirements. Do you have to fill out the Texas checklist form (photo), and do you then supply a typical software-generated report in addition to that?
Texas reporting requirements?-19-png
Kenton Shepard, CMI Inspector/Instructor
Director of Green Building
Designer/Builder: House of Horrors 1&2
Author: InterNACHI Narrative Library
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/30/17, 2:38 PM
Emmanuel J. Scanlan, TREC# 7593 Emmanuel J. Scanlan, TREC# 7593 is offline
Default Re: Texas reporting requirements?
Originally Posted by kshepard View Post
Although I know they're different from many states, I'm not really familiar with the Texas requirements. Do you have to fill out the Teas checklist form (photo), and do you then supply a typical software-generated report in addition to that?
It's not really a "checklist form". Each of the boxes are an indicator of how that section/subsection performed overall. Underneath each subsection are the issues found for that subsection.
The REI 7-5 is the required format for the actual inspection report that is provided to the client. Some slight changes can be made to it but those changes do nothing really to change this format.
Any reporting software vendor that sells to Texas Inspectors should be using this exact format for their auto generated report program. I say they should because TREC does not care what a software vendor sells the Inspector. TREC only cares what the Inspector provides the client. If an Inspector uses a non-compliant format due to their software vendor's product TREC is not going after the vendor but WILL go after the Inspector.
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
ICC Residential Combination Inspector
#5247015-R5 (Electrical, Mechanical, Plumbing and Building)
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 7/30/17, 7:04 PM
Chuck Evans's Avatar
Certified Master Inspector ®
Hey Kenton,
Inspectors must use the promulgated form in compliance with the Texas occupational code
§535.223 Standard Inspection Report Form
The inspector has a lot of latitude to extend the form, so long as he stays within the scope of what is OK to change. Basically, the boilerplate, major sections, check boxes and section number must remain in tact. The inspector can add subsections, cover pages, addenda, etc. within that framework.
3. An inspector may make the following changes to the standard form:
1. delete the line for name and license number, of the sponsoring inspector, if the inspection was performed solely by a professional inspector;
2. change the typeface; provided that it is no smaller than a 10 point font;
3. change the color of the typeface and checkboxes;
4. use legal sized (8-1/2" by 14") paper;
5. add a cover page to the report form;
6. add footers to each page of the report except the first page and may add headers to each page of the report;
7. place the property identification and page number at either the top or bottom of the page;
8. add subheadings under items, provided that the numbering of the standard items remains consistent with the standard form;
9. list other items in the corresponding appropriate section of the report form and additional captions, letters, and check boxes for those items;
10. delete inapplicable subsections of Section VI., Optional Systems, and re-letter any remaining subsections;
11. delete Subsection L., Other, of Section I., Structural Systems; Subsection E., Other of Section IV, Plumbing Supply, Distribution Systems and Fixtures and Subsection I., Other of Section V., Appliances;
12. as the inspector deems necessary:
1. allocate such space for comments in:
1. the "Additional Information Provided by the Inspector" section; and
2. each section provided for comments for each inspected item;
2. attach additional pages of comments; or
3. both;
13. include a service agreement/inspection contract or contractual terms between the inspector and a client with the standard form under the "Additional Information Provided by the Inspector" section or as an attachment to the standard form; and
14. attach additional pages to the form if:
1. it is necessary to report the inspection of a component, or system not contained in the standard form; or
2. the space provided on the form is inadequate for a complete reporting of the Inspection.
The two red lines allow for significant expansion over the required components of the report.
IIRC HomeGauge's default HTML based reports are not TREC compliant due to pagination, but the pdf outputted ones are. HG users can deliver both to the client so long as the "official" one is compliant.
Chuck Evans (TREC #7657)
The Woodlands Home Inspection
Houston, TX
_______________________
Awards Committee Member
Old 7/31/17, 12:00 AM
William B. Ogletree's Avatar
William B. Ogletree William B. Ogletree is online now
To your question, no, you do not have to provide the "checklist" form and narrative report separately.
Every inspection software inspection package I have looked (at least half-a-dozen) has an option for the Texas report format. It doesn't change the way you use the program (very much), just the appearance of the report.
For instance, I use HomeHubZone, which uses a room-by-room approach for inputting information (deficiencies and observations), and then collates that information into the major systems in the Texas report.
You will have fewer design options, but that's the way it goes.
William Bruce Ogletree
Ogletree Inspection Services
214-287-4630
www.ogletreehi.com
ogletreehi@gmail.com
Old 8/8/17, 12:28 AM
John Cahill, TREC 855 John Cahill, TREC 855 is offline
The Devil is in the Standards, not the form.
Old 8/8/17, 7:16 AM
Yes, the fairly ordered nature of the form is not the issue. The issue is long, long ago when TREC decided to kill the IAC and then rebuild it the SOP has gone to crap!! You, Strahan, and the rest of the crew on the IAC were well on their way to cleaning things up and TREC decided to end that!
TREC License# 7593
Old 8/21/17, 3:51 PM
Dan Bowers, CMI, ACI's Avatar
Dan Bowers, CMI, ACI Dan Bowers, CMI, ACI is online now
Mannie .............
I'm confused. Does it not make perfect sense that Realtors, TREC staff and attornies would know more about how a report should be compiled and look like versus a biased inspector.
Remember ONE very important thing. Texas and their promulgated report format has helped shape licensing in all other states.
Being on a national legislation committee for another home inspector association for years AND being on the BoD that set up the infamous NHIE .......... You need to always remember the Texas report format and TREC were labeled "The Hill to Die On" for other state inspector groups being pushed into licensure by the NAR and/or attorney groups.
"The Hill to Die On" ........... If it came down to the end AND they were for sure being jammed into licensure, most every other states inspectors would take almost ANYTHING as long as there was nothing like Texas report format and TREC in the Bill
Dan Bowers, CMI
Licensed Contractor / Builder
Certified IAQ2 Mold Inspector
Licensed HVAC Service Technician
EDI Certified Stucco / EIFS Inspector
iNACHI – US Member of the Year 2010
ITC / FLIR - Level I Infrared Thermographer
FHA - 203k Inspector / Compliance Inspector
ICC Code Inspector (Plmbg, Elec, Mech, Bldg)
Old 8/22/17, 12:36 AM
LOL LOL
I actually like the form for the most part. It is a logical format for reporting but can use some tweaks.
It's the SOP that has been degenerating since Cahill, Strahan, and Crew were dumped when TREC disbanded the Inspector Advisory Committee (IAC), and then restarted it less than a year later with a "Hand Picked Crew".
TREC License# 7593
Old 8/22/17, 7:29 AM
Michael R. Boyett's Avatar
Retired Member
Yeah, but it was fun overwhelming the "new IAC" with Request for Interpretations for 18 months after that.
Old 8/22/17, 8:55 PM
Yes it was wasn't it!
TREC License# 7593
Old 8/23/17, 8:55 AM
Nolan Kienitz's Avatar
Nolan Kienitz Nolan Kienitz is offline
Retired Member
And they still have not recovered!!
So now they attack the CE training and we are left with garbage.
Cheers,
Nolan E. Kienitz
TREC # 7095
Nolan's Inspections
www.NolansInspections.com
Old 8/25/17, 11:23 AM
Mannie .................
To most inspectors in other states (I've lived and worked in 5) the Texas form is minimalistic and not the way they inspect.
However, if I had never done OR used another format I might think that way.
One thing that comes to mind is the call I get from an investor ........... He's looking at 3 houses BUT only gonna buy 1. He does NOT want FULL inspections at this point .......... He just wants me to go with him and do a "Walk & Talk" ....... NO report / NO climbing on Roof or Into Attic; NO taking Electric Panel Cover off ................. just comment on what I can visually see (60amp panel with 2 sub-panels / 3 layers of roof visible at eaves; ACM on ducts; etc).
He then picks one ........ makes an offer AND if he gets it, WE inspect it. The "Walk & Talk" we charge $150 for. Its WHAT the client wants. Same as on a EIFS or Stucco house ....... Buyer wants moisture test / Seller OR listing agent throws a hissy and won't allow PROBING, so BUYER hires us to do a "Walk & Talk" on the Architectural Details (almost always something(s) are wrong, missing, etc AND now Seller is either gonna ALLOW probing OR have to DISCLOSE the BAD / WRONG details that are PRONE to MOISTURE intrusion to NEXT potential buyer. SOFTENS the seller up and usually results in a FULL moisture probe type test.
I constantly get told under TREC rules you could NOT do the
"Walk & Talk" which seem ludicrous when THAT is what a CLIENT wants.
Dan Bowers, CMI
Old 8/25/17, 3:44 PM
Dan,
The Texas required form is not a tool for the "inspection". It is for writing the report. A Texas Inspector can choose to inspect any way they wish as long as they document it in the proper area of the report form. As a matter of fact for an Inspector who can not generate their own routine, and who has problems putting their observations in the right sections of the form, the report software companies already do that for them within the reporting software. Although anyone who needs a software program to figure out how to inspect and where to document their findings should seriously consider another line of work!
I have absolutely no idea where you came up with the concept that the Texas form is "minimalistic"??? In fact the form covers every system or subsystem of a home that the Inspector is required to inspect as per the Texas SOP. The form itself is also easily expandable to cover anything else the Inspector chooses to inspect that is not required by the Texas SOP. The form itself can be used in many different reporting styles.
As for "never done OR used another format" I have been writing reports most all of my life for one job, function, position, or another. I've seen many if not all the various styles of report writing techniques and theories. This form is a logical approach to a logical function.
I have no idea how you drifted into the "Walk & Talk" subject when the original subject is about the Texas required reporting form. There is already an ongoing discussion of Texas and the "Walk & Talk" concept here https://www.nachi.org/forum/f2/wrong...t-foot-123987/ . As for TREC's rules with regards to a "Walk & Talk" being "ludicrous" you would need to take that up with them.
TREC License# 7593
Old 8/25/17, 7:09 PM
Mannie ........... Many inspectors all across the country as well as long time Texas inspectors also call it minimalistic BUT as you indicated it meets the Texas SoP. By the way, do the Texas inspectors decide what format they will use OR is someone else in charge of that?
Dan Bowers, CMI
Old 8/25/17, 10:27 PM
Dan,
You're cherry picking only part of my response in an attempt to make your point. However just as important as the single sentence you quoted is the sentence here that I have placed in bold.
There are plenty of Inspectors that choose only to perform the minimal requirements outlined by TREC. There are also other Inspectors that choose to exceed those requirements. For those that choose to exceed the requirements they can expand this form to cover that.
With reference to your question in bold above what "format" specifically are you referring to?
TREC License# 7593
