Florida Home Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida home inspection topics, wind mitigation inspections and 4-point inspections. Become a home inspector in Florida
Old 3/8/11, 8:27 AM
Thomas A. Kenney Thomas A. Kenney is offline
Default Bathroom fans and venting
can anyone inlighten me on venting a bathroom fan into the attic, i have a realtor telling me that it's OK to vent a bathroom fan into the attic and it doesn't have to be vended outside.I wrote it up and said it should be vent outside,
any codes on this ?
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/8/11, 8:42 AM
Roy D. Cooke, Sr's Avatar
Default Re: Bathroom fans and venting
any codes on this ?
I am not a code Inspector .
They do need to go to the out side .. Roy
https://sites.google.com/a/etccreati...ac/bathventing
Old 3/8/11, 8:50 AM
William E. Siegel William E. Siegel is offline
This might help:
From the IMC:
- 501.2 Exhaust discharge. The air removed by every mechanical exhaust system shall be discharged outdoors at a point where it will not cause a nuisance and not less than the distances specified in Section 501.2.1. The air shall be discharged to a location from which it cannot again be readily drawn in by a ventilating system. Air shall not be exhausted into an attic or crawl space.
- - Exceptions:
- - - 1. Whole-house ventilation-type attic fans shall be permitted to discharge into the attic space of dwelling units having private attics.
- - - 2. Commercial cooking recirculating systems.
From the IRC:
- M1501.1 Outdoor discharge. The air removed by every mechanical exhaust system shall be discharged to the outdoors. Air shall not be exhausted into an attic, soffit, ridge vent or crawl space.
- - Exception: Whole-house ventilation-type attic fans that discharge into the attic space of dwelling units having private attics shall be permitted.
Old 3/8/11, 9:10 AM
jnieblas's Avatar
jnieblas jnieblas is offline
Please Note: jnieblas is a non-member guest and is in no way affiliated with InterNACHI or its members.
any codes on this ?
This should help:
The air removed by every mechanical exhaust system shall be discharged outdoos at a point where it will not cause a nuisance and not less than the distance specified in Section 501.2.1.
You also have two exceptions in this section but they do not apply to your case.
This is from FBC 2007 Mechanical Chapter 5 Exhaust Systems Section 501.2 Exhaust discharge.
Old 3/8/11, 9:35 AM
Thomas Hession's Avatar
Thomas Hession Thomas Hession is offline
Home Inspections 101...
Tom Hession
HHH Home Inspection Services LLC
Pinellas Park, Fl.
727-504-5053
http://www.pinellasinspector.com/
http://www.hhhhomeinspections@gmail.com
Home, Health, Happiness
Old 3/8/11, 10:16 AM
Michael Larson's Avatar
Michael Larson Michael Larson is online now
I think I see the problem.
As a Professional Home Inspector, I support the privacy of my clients.
You own your private information. I won't sell or give away yours, others do
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 3/8/11, 11:45 AM
Joseph Burkeson, CMI's Avatar
Joseph Burkeson, CMI Joseph Burkeson, CMI is online now
Certified Master Inspector
any codes on this ?
When was the house built? Under what code?
The problem of bathrooms venting into the attic is not as great an issue here in Florida as it is in cold climates where it is common to find a vapor barrier between the conditioned and non-conditioned spaces.
BTW... I see this all the time in homes which are 25 years or older and have never seen any damage related to the issue.
Yes, I'd personally choose a CMI every time over every other inspector. ~ Nick Gromicko, InterNACHI Founder
Certified Master Inspector - 2010
Florida Licensed Home Inspector - HI176
Florida Licensed Mold Assessor - MRSA208
Square-One Inspection "Assurance begins here"
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 2:23 AM
Please proof this article: Bathroom ventilation ducts and fans. gromicko Interior Inspections 4 4/3/09 11:04 PM
Bathroom fan venting cduphily Exterior Inspections 24 2/20/08 1:04 PM
Bathroom ventilation brian winkle Electrical Inspections 12 6/12/06 8:30 PM
Bad Dryer and Bath Fan Venting Jkrt00 Inspecting HVAC Systems 3 3/14/06 12:07 AM
