Florida Home Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida home inspection topics, wind mitigation inspections and 4-point inspections. Become a home inspector in Florida
Old 10/11/12, 3:03 PM
Eric C. Van De Ven, CMI Eric C. Van De Ven, CMI is online now
Certified Master Inspector ®
Default Clips, wraps,its all bs
A while ago, I posed a question regarding a single strap that came out of a concrete wall and was nailed to a truss with several nails. This is as per the OiR and 1802, classified as a clip. Two of the same type of strap, on the same truss is also classified as a clip.
I e mailed Simpson with regards to this issue and here was thier reply:
Sir-
My understanding is that the classifications were developed in order to make inspection easy, so there are not any load ratings officially associated with each of the options (clip, single wrap, double wrap strap).
A single embedded truss anchor simply nailed to the side of a truss could have the same capacity as a single wrap strap with fewer nails, and the same could be said for two embedded truss anchors having the same capacity as a double wrap strap.
However, I am not aware of any allowance for reclassifying connectors based on capacity.
We actually pursued this during the revision of the inspection form, and were unsuccessful.
My new question would be, why is the OiR making the classifications and not the manufacturers?
This merely adds to the growing amount of evidence that the 1802, the discount program, and everything connected to it, is a complete scam.
Clips, wraps,its all bs-duke2-81-jpg   Clips, wraps,its all bs-duke2-84-jpg
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/11/12, 7:43 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Default Re: Clips, wraps,its all bs
Sir-
Be careful what you wish for. Can you imagine doing an engineering analysis on each type of RTW you encounter? Your blood pressure would be a lot better off if you would just quit bucking the process. The form is geared toward common connection types and that is what it should be. Doesn't make it completely right, but simplifies things. Most of the heavy duty connections were only introduced recently on homes already getting the FBC credits. This form is geared more for the older homes.
Old 10/11/12, 10:24 PM
The form dictates what, if any discounts a homeowner will get.
If as I suspect, the rating for the picture above is a double wrap and being marked as a clip, how much of he discount isn't being applied.
What is even more disturbing,is the fact the OiR has the information and chooses not to use it. Just like the data from Simpson which stated that a single wrap with two nails on one side and one on the other, was a single wrap, not a clip as previously classified on the earlier form.
They along with the insurance companies are using false or in some cases, no data, to come up with a rating which is costing people, while at the same time, lining the pockets of the insurance companies.
As for my blood pressure, it is fine.
Old 10/12/12, 12:01 AM
William E. Siegel William E. Siegel is offline
Can you imagine doing an engineering analysis on each type of RTW you encounter? How do you think the homes were built. Each home had a rational analysis performed to determine wind load and uplift. The only people doing these inspections should be engineers and architects as they are the only ones who are truly qualified. But then again that would knock all of you $75.00 gurus out of business.
Old 10/12/12, 7:14 PM
William C. Chandler William C. Chandler is offline
Amen to that.
www.thebuildinginspector.net
William Chandler
Licensed Home Inspector #1025
Certified General Contractor #CGC060389
HUD 203K Consultant #A0954
Licensed Radon Measurement Technician #R2275
Old 10/19/12, 10:13 AM
I must admit, on occasion, I get surprised! Pleasantly!
I just sent around 70 pictures of all different straps to someone from Simpson who is attending the ATC hurricane conference. Perhaps another revision to the form is in the works!
Clips and Wraps according to 1802 mmeeker Florida Home Inspectors 22 10/14/12 10:22 AM
clips or other phalstead Florida Home Inspectors 34 7/4/11 8:23 AM
h clips nbhi Structural Inspections 23 5/8/09 11:48 PM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 3:28 PM
