Florida Home Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida home inspection topics, wind mitigation inspections and 4-point inspections. Become a home inspector in Florida
Old 10/28/14, 4:46 PM
Shawn D. Staggs, CPI's Avatar
Shawn D. Staggs, CPI Shawn D. Staggs, CPI is offline
Community Guest
Default Hip Roof shape or other
Doing a wind mitigation on this old 1942 home. Most of the roof is hip on the front porch area one side is hip while the other side is like a gable end. Would this be other or hip. Here some photos.
Hip Roof shape or other-1414529130486-jpg   Hip Roof shape or other-20141028_164208-jpg   Hip Roof shape or other-20141028_164245-jpg
Anchor Bay Inspections
Florida Licensed Home Inspector HI8446
941-676-2375
Serving Sarasota, Bradenton, Longboat Key, Anna Marie Island
Holmes Beach, Palmetto, Venice, Port Charlotte and Punta Gorda
Home Inspection - Wind Mitigation - Four Point Inspections
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/28/14, 4:50 PM
Michael J. Meeker, CMI's Avatar
Michael J. Meeker, CMI Michael J. Meeker, CMI is online now
Certified Master Inspector ®
Default Re: Hip Roof shape or other
Do the math looks likely other to me.
<div align=center>
Quality Control Consultants. Pre-Purchase Building and Home Consultations
FLORIDA LICENSED GENERAL CONTRACTOR & CERTIFIED MASTER INSPECTOR
Call 954-922-0584 or E-Mail Me For The Best Consultations or Inspections in Florida.
mike@meekerindustries.com
http://www.meekerindustries.com
Also Check out these two great sites below for a HEALTHIER LIFE !
mikemeeker.towergarden.com & mikemeeker.juiceplus.com
Old 10/28/14, 5:00 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Pic 3 looks like an unenclosed porch with the roof attached to the wall...don't count that one. Pic 2 has gable sections on the end walls. Now you have to decide on total roof perimeter...upper and lower, or just lower, or just upper...inquiring minds want to know.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 10/28/14, 5:07 PM
Roy Lewis, CMI's Avatar
Roy Lewis, CMI Roy Lewis, CMI is online now
Hip with the exclusion of the lean to.
There ain't no gables or flats..Huh?
InterNACHI Lifetime Member.
www.1stproinspection.com
roy@1stproinspection.com
Serving Gainesville Florida and surrounding areas.
Florida Certified Contractor #CRC1328001
Florida Certified Home Inspector #HI7019
Deus solus me iudicare potest
#1st Pro Inspection
Well! They may have degrees, but that is not an indicator of common sense or right thinking...M. Larson circa 9-27-2018.
Old 10/28/14, 6:22 PM
My bad I believe Roy is correct. I should look harder Everything I see is attached to the walls.
<div align=center>
Old 10/28/14, 6:33 PM
Look at this Shawn
Hip Roof shape or other-roof-types-jpg
#1st Pro Inspection
Old 10/28/14, 7:05 PM
Community Guest
Well just letting you guys know it came with 7% non-hip other. this type of roof shape is the stuff that gets me really confused when it comes to a wind mitigation, but once you do a couple of them to start getting better at them.
941-676-2375
Old 10/28/14, 7:07 PM
Community Guest
I know the difference between hip and gable and measuring the roof shapes its just when I get odd ones like that I have to come to ask.
thanks guys for your help.
941-676-2375
Old 10/28/14, 8:16 PM
Roy was correct when attached to wall it does not matter.
<div align=center>
Old 10/28/14, 8:55 PM
Only if it is not enclosed (screened or open), and it's not part of the same roof that is over a portion of enclosed space.
Brad K Toye
727-403-5029
Lecsi2@gmail.com
Old 10/28/14, 8:57 PM
Community Guest
So enclosed room counted, Open or Screen covered porch not counted??
941-676-2375
Old 10/28/14, 8:59 PM
That's right. One of your bump out rooms is enclosed...those gable ends count as non-hip.
Brad K Toye
727-403-5029
Lecsi2@gmail.com
Old 10/28/14, 9:02 PM
Community Guest
The guys home actually did good, Measured the entire Hip perimeter and came out to be 7% non-hip
941-676-2375
Old 10/28/14, 9:03 PM
That's about what it looks like from my house.
Brad K Toye
727-403-5029
Lecsi2@gmail.com
Old 10/28/14, 9:06 PM
Michael Koester's Avatar
Michael Koester Michael Koester is offline
Are unenclosed spaces ever counted?
Falling Off A Roof dbowers Roofing Inspections 33 7/30/14 6:04 PM
Word count of our inspection narratives as of today tops 300,000 words. Wow. gromicko Miscellaneous Discussion for Inspectors 47 12/21/12 8:09 PM
Count or Not Count towards Wind Mit. Report dsemmel Florida Home Inspectors 119 2/20/12 9:25 PM
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services 17 7/12/11 6:31 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 12:21 AM
