Florida Home Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida home inspection topics, wind mitigation inspections and 4-point inspections. Become a home inspector in Florida
Old 2/23/15, 10:15 AM
Michael Koester's Avatar
Michael Koester Michael Koester is offline
Default Icynene
Wind Mitigation Question - Sorry if this has been asked before but if you encounter icynene - how do you proceed?
Thanks
Michael Koester - Certified Professional Inspector
Direct Inspections
6528 Seagate Ave, Sarasota, FL, 34231
(941) 251-1000
https://www.DirectInspections.com
michael@directinspections.com
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/23/15, 12:36 PM
William H. Smith, HI1354 William H. Smith, HI1354 is offline
Default Re: Icynene
Reacts slowly with water to produce carbon dioxide which may rupture
closed containers. This reaction accelerates at higher temperatures.
Inhalation at levels above the occupational exposure limit could cause
respiratory sensitization and risk of serious damage to respiratory
system. The onset of the respiratory symptoms may be delayed for
several hours after exposure. A hyper-reactive response to even
minimal concentrations of diisocyanates may develop in sensitized
persons.
Not good for Florida but then most foam has a reaction to water and higher static temps regarding emissions. Little difficult to specify exact type of foam unless MSDS sheets or other docs. available.
Pics and narrative as to closed or open cell and how it is being used, insulation, adhesions etc.
Old 2/23/15, 12:41 PM
Roy D. Cooke, Sr's Avatar
Default Re: Icynene
Thanks
http://greenhomeguide.com/askapro/qu...tion-of-a-home
Old 2/23/15, 11:57 PM
Kenneth Jones Kenneth Jones is offline
Default Re: Icynene
Every million dollar new home I work on has it. Only problem I know about is off gassing while spraying and for a few days after.
Old 2/24/15, 5:50 AM
Default Re: Icynene
Sorry, I was asking about wind mitigation. Having a blonde moment.
Direct Inspections
(941) 251-1000
Old 2/24/15, 8:40 AM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
Default Re: Icynene
Thanks
Take a photo of the insulation and select "unknown" due to obstructions. That's all you can do. Most of the time, the SPF will not be over the garage though.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 2/24/15, 4:00 PM
Default Re: Icynene
Thanks
Direct Inspections
(941) 251-1000
Wind Mit - Icynene mkoester Florida Home Inspectors 2 8/16/14 1:02 PM
icynene 1/2 lb. foam aborbing moisture. knolan Green Building Inspections 11 9/16/12 8:43 AM
Icynene Insulation rcooke Canadian Home Inspectors 1 3/28/08 6:22 PM
Icynene: first good look at it. kshepard Structural Inspections 21 12/10/06 6:36 PM
