Florida Home Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida home inspection topics, wind mitigation inspections and 4-point inspections. Become a home inspector in Florida
Old 1/13/19, 6:00 PM
Ian Coates Ian Coates is offline
InterNACHI Applicant
Default Moisture intrusion in Florida homes
I am very unimpressed by the florida building industry and its apparent disregard to build watertight homes. I understand that in Florida homes are built to withstand the hurricane force winds, but the wall design of almost every home built in Florida relies on Paint only to keep the water out of the building. Take second storeys in homes which are timber built and are rendered stucco onto mesh. When the stucco cracks, (and it always does) it lets water in to the mesh which then rusts and blows off large amounts of stucco. Its so obvious that this is going to happen and yet the industry is continuing to build with systems that are known to be defective.
If only every consumer realised that their $450,000 home is only protected from the elements by a $4000 paint job that needs doing every 4 years at the most.
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/13/19, 6:12 PM
Michael J. Meeker, CMI's Avatar
Michael J. Meeker, CMI Michael J. Meeker, CMI is online now
Certified Master Inspector ®
Default Re: Moisture intrusion in Florida homes
Stucco is not waterproofing. Simple solution id just build of concrete or blocks. The sad part is that the builders blame the stucco guys who HAVE to build by the plans their idiotic architects create.
<div align=center>
Quality Control Consultants. Pre-Purchase Building and Home Consultations
FLORIDA LICENSED GENERAL CONTRACTOR & CERTIFIED MASTER INSPECTOR
Call 954-922-0584 or E-Mail Me For The Best Consultations or Inspections in Florida.
mike@meekerindustries.com
http://www.meekerindustries.com
Also Check out these two great sites below for a HEALTHIER LIFE !
mikemeeker.towergarden.com & mikemeeker.juiceplus.com
Old 1/13/19, 6:21 PM
True. But even concrete block when not painted often enough is not water repellent enough in a bad storm. The block gets saturated and fills and then runs out into the home as the bottom of the house on the outside is painted enough to stop the water draining to the outside. When that happens the house gets the ground floor flooded and damage to the interior even though the house is not in a flood zone.
Companies will not address the issue unless they are forced to, and that is the really sad part. A building code that doesn't protect the consumer and as long as the consumer is in the dark, there will be no change
Old 1/13/19, 7:51 PM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
The FBC requires that homes are protected from water infiltration. It's usually workmanship errors or subpar building materials that cause most of the problems. Stucco contractors are slowly learning their errors, and many builders are turning toward cement fiber siding instead of stucco. There are many yahoos down here that really don't care much what happens after they leave the job site.
Brad K Toye
ITC/FLIR Level I Building Investigation Thermographer
FL Certified Building Contractor CBC034303
FL Certified Home Inspector HI 391
FL Certified Mold Assessor MRSA 589
727-403-5029
Lecsi2@gmail.com
Old 1/16/19, 10:07 AM
Preston L. Halstead, HI549 Preston L. Halstead, HI549 is offline
Why would the stucco guys not follow proper stucco standards? Or is that a Florida thing? I was shocked to see how improper it was done when I first came here. It was a hard argument to have when every single house you could point to was also done incorrectly. They are starting to learn now. I would agree it is not waterproofing and that is why proper installation is required.
Preston L. Halstead
VP FL Home & Insurance Inspectors Chapter
Elite Property Inspection & Management
LICENSED GENERAL CONTRACTOR CGC1515203
LICENSED BUILDING INSPECTOR BN6262
LICENSED HOME INSPECTOR HI549
561-420-0277
HOME INSPECTION ~ WIND MITIGATION INSPECTION
Serving Boca Raton, Boynton Beach, Delray Beach, Juno Beach, Jupiter, Lake Park, Lake Worth, Lantana, North Palm Beach, Palm Beach, Palm Beach Gardens, Royal Palm Beach, Wellington, West Palm Beach.
Old 1/17/19, 1:13 PM
Builders hire the cheapest people they can ever since the crash. Before the crash the stucco guys did what the builders told them to do. Most problems are caused by lack of supervision by both the Stucco guys and the builders. I still can walk just about any site and find issues
<div align=center>
Old 1/18/19, 7:59 PM
Mike Pagozalski, CMI Mike Pagozalski, CMI is offline
I would think you must make a fortune doing invasive stucco inspections
Mike Pagozalski
Mike@InspectTally.com
850-528-5585 (Cell)
FL Certified Home Inspector HI9519
FL Licensed Real Estate Broker BK3055789
FL Radon Measurement Technician R2530
ITC Level II Thermographer #150761
Exterior Design Institute (EIFS/Stucco) #FL131
Tallahasee's Home Inspection Team
Tallahassee Radon Testing
Tallahassee Home Inspector
Old 1/20/19, 5:24 PM
I am thinking about starting remediation for stucco issues but am having a hard time figuring the best way to keep the exposed walls dry while waiting for insections and stuff.
Any ideas would be greatly appreciated.
<div align=center>
Old 1/21/19, 3:29 PM
That is what I am saying. The stucco industry in Florida never learned how to properly install stucco.
Preston L. Halstead
561-420-0277
Old 2/3/19, 7:31 PM
Coming from the UK, we always had trouble with Stucco on very hot days there. Considering the hot days here are even hotter and more often, I don't believe that stucco is the answer to keeping a house dry. Stucco in the UK is basically a decorative treatment on new homes and only used as waterproofing on homes built with solid walls ie brick and stone/no cavity. I believe the problem is within the design of the house. But that would make them more expensive...
The real problem is that houses are being built to only last a few years and no one knows but the contractors who are building them.
Old 2/4/19, 1:48 PM
I agree with you Ian. Poor design id the root of many problems.
<div align=center>
Old 2/5/19, 9:46 AM
Although to some regard I agree with you, it still doesn't change the fact that Florida has no idea how to install it. More recently you will see it done properly but hardly ever, if ever was it done right in the past. How many houses are seen with a weep screed, expansion joints, or casing beads? Then you add in improper thickness applied, mixed incorrectly, applied in the hot sun, and poorly maintained by the homeowner.
Preston L. Halstead
561-420-0277
