Florida Home Inspectors This is a place for Florida InterNACHI inspectors to discuss Florida home inspection topics, wind mitigation inspections and 4-point inspections. Become a home inspector in Florida
Old 4/17/13, 10:53 PM
Wayne Collier, HI5099's Avatar
Wayne Collier, HI5099 Wayne Collier, HI5099 is offline
Default Opening Protection
Opening protection installed inside the window well. Can't recall seeing this anywhere before. Anyone know if this would get kicked back and have documentation noting yay or nay?
[ATTACH]64270[ATTACH]64271
Opening Protection-sam_3938_renamed_17676-jpg   Opening Protection-sam_3937_renamed_20454-jpg
Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/17/13, 11:02 PM
Humberto Carvajal, HI884's Avatar
Humberto Carvajal, HI884 Humberto Carvajal, HI884 is offline
Default Re: Opening Protection
I've seen it done with plywood before. I'm only guessing here Wayne but if it's allowed with wood I can't see why it wouldn't be in your case. I've even seen the protection on the inside of the home before in the case where they have wrought iron bars.
Bert
<div align=left><a href=http://www.afloridainspection.com target=_blank>[SIGPIC]
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEED® Accredited Professional
Member USGBC South Florida Chapter
Old 4/17/13, 11:09 PM
Kevin House Kevin House is offline
Wayne,
After the code change in 2001, one distributor in Lee County sold some that met the and they had the 1/4 inch removable bolts (F track) on the top and bottom. It met the FBC I'm pretty sure.
But it did put all of the load onto the window (which doesn't seem as strong as the outside mount).
The shutter distributor here, (Town & Country) sells the U track like is shown in your photo.
Old 4/17/13, 11:12 PM
Bert
That's where the confusion comes in, we know it must be anchored to the home but does inside the well qualify? Those plywood clips you buy at the hardware store are a no go.
Old 4/17/13, 11:16 PM
Originally Posted by khouse1 View Post
Wayne,
That's one of my arguments also is the load on the actual window. There has to be a written standard somewhere. Homeowner said the county building dept signed off on the final. What do they know? this was in 2005 and 12,000 dollars of metal track. I think they got hosed personally. If it's to insurance standards I am fine with it just want some clarification.
Old 4/17/13, 11:50 PM
Wayne,
I'm pretty sure those are OK; T&C sells different ones and they have a spec sheet that meets the FBC.
Here is one sheet:
http://www.floridabuilding.org/uploa...24_drawing.pdf
Old 4/18/13, 12:05 AM
Wayne,
Here is one sheet:
Thanks, I see the inside diagram
Old 4/18/13, 9:45 AM
Bradley K. Toye, CMI's Avatar
Bradley K. Toye, CMI Bradley K. Toye, CMI is online now
Certified Master Inspector
You should be able to verify that installation with the correct drawing for that particular product. I have not seen one yet approved for inside the opening, and I don't see one in those drawings for the Steel Panels either. Some have a min distance between the panel and the glazing such as 4". Could be an issue for an auditor that knows what he is doing, so I would do a bit more reseach on them.
Old 4/18/13, 11:23 PM
The sheet above shows approval for an inside opening like many since 2002.
Old 4/19/13, 12:00 AM
I stand corrected...didn't zoom out the page. However, that installation sheet doesn't work for the target product in the first post.
Old 4/19/13, 10:46 AM
Sean Harding Sean Harding is offline
Please Note: sharding is a non-member guest and is in no way affiliated with InterNACHI or its members.
Wayne, your job is not to be a city or county inspector. They are the ones who look at the product approval. If the window protection is present, you call it out that way. In truth it can be installed inside the opening, subject to the anchors being a minimum distance from the edge, (and that varies depending on the substrate) and the panel being a minimum distance from the glass. We are not there to approve the installation, as that is not part of an inspection.
Old 4/19/13, 4:59 PM
As a home inspector you should know something about what you are reporting. Product approval? when was the last time you did a wind mit? we look for product approval many times a day. For your info non member I gave her the credit. All you had to say was in your experience and maybe provide something to back it up. You instead attack my reporting as if you have seen it. GFY
Old 4/19/13, 6:46 PM
Jay C. Murray's Avatar
Jay C. Murray Jay C. Murray is offline
As long as it covers the opening and is attached to structure and not the window itself, it should be acceptable. If anyone knows otherwise, I would like to be informed. It is certainly acceptable if the product approval docs approve that for of installation.
Your Home Inspection & Wind Mitigation Provider
Jay C. Murray
Florida Home & Insurance Inspector Chapter Board Member
Licensed General Contractor & Home Inspector
Serving Port St. Lucie, Ft. Pierce, Stuart, Palm City, Jensen Beach,
The Palm Beaches, & The Treasure Coast
Old 4/19/13, 6:59 PM
Sharding,
I hate to pile on, especially when Wayne did such an excellent job.
But seriously, we are talking about wind mitigation inspections specifically. If you are a real inspector, you will need to understand why such questions are so important. It's not that Wayne needs 'help'. We are all trying to better educate and prepare NACHI inspector by posing any kind of unusual situation or condition.
If you are an inspector or want to be an inspector, you better start paying attention. Wind mitigation will make you or break you. Based on your comments you need some education regard insurance inspections.
Jay C. Murray
Old 4/22/13, 9:50 AM
Wayne, try reading my answer. I said you can install panels inside the opening. I also said it was not part of the inspection to look AT the product approval. But while we are on that subject, if you did look AT the product approval you would see if that particular panel can be installed as in the picture. My point was that it is not part of the inspection to second guess an installation. You have to make sure it has an approval not that the installation is done in accordance with that approval.
Jay, I'm well aware what we are writing about. I said you do not have to look at the approval, (to see that the installation complies), just make sure that it has one!
Citizens Insurance, Opening Protection and Claim Payments mwagner Florida Home Inspectors 0 7/25/12 9:44 PM
Just found this about GFCI protection..just some FYI rhensel Electrical Inspections 10 6/24/12 12:51 AM
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 10:51 PM
Wind Mit Opening Protection ? fsylvester Florida Home Inspectors 8 11/15/10 12:57 PM
Scenario #5- Opening Protection dbonner Florida Home Inspectors 12 8/16/10 1:04 AM
