What would be the geometry of this roof? The inspection was done for the end unit that has 3 sides hip. This unit ends before the window on the 2nd floor on the inside corner and before the tie in to that gable section. That area is over another unit. Do you take the whole roof into consideration or just the area over unit?
Thanks Guys
Bruce Waits
First Choice Inspections
St. Petersburg, Fl.
I am confused. Why would they loose the hip rating due to the lower roof, even if just this unit was considered? That roof is hip too. Just to be clear, the entire roof should be included on this one.
