Since this Deck is not structurally attached to the main roof…do you count it towards the overall roof dimensions.
Thanx in advance…
Thanx in advance…
If over heated space, I would say yes.
I would agree with Richard, except for the heated space. I would call it living space. If a patio is not used as living space(heated/cooled), can be closed to the home by an exterior door and is not structurally attached, then I would not count it.
Great example, thanks for posting.
i would count it too
Yes, if it is over living space and greater than 10% of the total roof area.
Thank you…Would the new form change this designation in any way…it’s over 10%
it is a flat roof which appears to be >10% of the total roof area
Under the proposed changes it would be a ‘Other Roof’ shape, IF the perimeter of the flat is greater than 10% of perimeter.
