Student Discussions This is a forum for discussing InterNACHI's Inspection Courses.
Old 10/11/12, 4:05 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is online now
InterNACHI Staff
Default "Advanced Training for Inspecting HVAC Systems for Home Inspectors" online course
This thread is dedicated exclusively for those students currently enrolled in the InterNACHI course titled, "Advanced Training for Inspecting HVAC Systems for Home Inspectors."
Upon successful completion of this course, the student shall be able to:
  • inspect heating and cooling systems;
  • evaluate the basic performance of HVAC systems; and
  • identify major defects common to HVAC systems.
Students are free to pose questions and comments here and join in the conversation with other students. The thread will be monitored by the course instructor.
Contact: Director of Education, Ben Gromicko ben@internachi.org
Inspector training courses: www.nachi.org/education.
Thank you.
Ben Gromicko
InterNACHI C.O.O. & Education Director
NACHI.TV Executive Producer
Certified Master Inspector®
Certified Professional Inspector®
InterNACHI Residential Standards of Practice
IAC2 Mold Standards of Practice
Radon Mitigation System Inspection Standards of Practice
Author 12 Home Inspection Textbooks
Author 2 Home Maintenance Books
Author of 77 Online Education Courses
Producer of More Than 400 Training Videos
Instructor of Over 30,000 Students in Live Online Classes
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/9/13, 9:34 PM
Neil Riley Neil Riley is offline
Default Re: "Advanced Training for Inspecting HVAC Systems for Home Inspectors" online course
Looks like it will be a great course. So let's get started...
Old 3/20/13, 6:25 PM
Mark W. Silliman Mark W. Silliman is offline
Appreciate the great course available to us!
Old 4/22/13, 6:32 PM
David Astorina's Avatar
David Astorina David Astorina is offline
This does look very good! I'm also taking the BPI Heat Pro Class, It will be interesting to see the differences. Looking forward to learning a lot!
Dave
Old 4/26/13, 12:07 AM
Matt Martin Matt Martin is offline
starting the advanced HVAC course now...
Old 4/27/13, 8:46 PM
Chad McCormick Chad McCormick is offline
Old 6/3/13, 5:10 PM
Paul Manicone Paul Manicone is offline
InterNACHI Student
Looks awesome
Old 6/15/13, 5:19 PM
Mark Trimble's Avatar
Mark Trimble Mark Trimble is offline
Send a message via Yahoo to mtrimble Send a message via Skype™ to mtrimble
Please Note: mtrimble is a non-member guest and is in no way affiliated with InterNACHI or its members.
Im confused. In Part 5 you tore apart a furnace because a Home Inspector called out a crack in the heat exchanger, but the lesson seemed to indicate as a home inspector we only do visual inspections, so we would be unable to see such a crack, yet you pulled it apart and there was in fact a crack. How did the home inspector determine there was a crack?
Old 6/26/13, 12:03 AM
Edward H. Cunningham Edward H. Cunningham is offline
I am a licensed HVAC contractor and it will be probably be interesting experience taking this course. I will comment further after I complete the course.
Old 6/26/13, 12:06 AM
Maybe he or she had a camera with a 24" flexible lighted tip..
Old 6/26/13, 8:49 AM
Hank Vanderbeek, MPA, CMI Hank Vanderbeek, MPA, CMI is offline
Nice job as Dir of Edu Ben! You had big shoes to fill with Gerry.
Quick question. Does the course cover zone valves in relation to circulator pumps and vent dampers on a boiler system?
Old 7/3/13, 1:22 AM
Bill Heath, CMI Bill Heath, CMI is offline
Certified Master Inspector ®
Thank You
Old 7/3/13, 2:19 PM
InterNACHI Staff
Yes.
boilers: classification, water, steam, fuel type, material of contruction, dry base, wet base, water tube, fire tube, type of draft, condensing, wall hung, integrated domestic coil, components, gas valve, safety controls, burner assembly, heat exchanger, temperature pressure relief valve, auto fill valve, sight glass, low water cut off, expansion tank, zone valves, circulator pump, air separator, temperature gauge, high low limit control, backflow preventer, oil burner, pump, blower, nozzel, ignitor, transformer, electric motor, air shutter, reset switches, cad cell, stack switch, radiators, convectors, finned tube, fan coil, etc.
Visit https://www.nachi.org/advanced-traini...deo-course.htm and scroll down the page for a full description of what's covered in the course.
Thank you.
Ben Gromicko
Old 8/17/13, 12:11 AM
Stone Li Stone Li is offline
Just a quick question,
Could PVC or ABS pipe be used as high efficiency furnace air intake and flue pipe?
Old 9/17/13, 12:16 PM
Thomas Dutkus Thomas Dutkus is offline
Teach me Seymor, teach me.
Emergency Lighting (commercial) mcyr Electrical Inspections 26 6/20/14 11:00 PM
If someone can get me CAHPI's and OAHI's I'll add them... gromicko Canadian Home Inspectors 72 4/7/08 8:39 PM
online courses? Jerame Schueler Inspection Education & Training 17 12/16/07 1:15 PM
Frree online access to Field Training Manual from PHII. gromicko Special Deals for InterNACHI Inspectors 3 8/25/07 7:49 AM
