Student Discussions This is a forum for discussing InterNACHI's Inspection Courses.
Old 2/11/15, 5:02 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
InterNACHI Staff
Default How to Inspect Water Heater Tanks Course
This online student thread is dedicated exclusively to students who are currently enrolled in InterNACHI's free, online "How to Inspect Water Heater Tanks" video course.
Students may pose questions, share thoughts, discuss topics, and post images related to this course. The thread is monitored by the course instructor.
Need assistance? Ben Gromicko ben@internachi.org
BEN GROMICKO
View Profile
InterNACHI Chief Operating Officer
InterNACHI Chief Academic Officer
NACHI.TV Producer and Host
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/11/15, 5:21 PM
Shawn D. Staggs, CPI's Avatar
Shawn D. Staggs, CPI Shawn D. Staggs, CPI is offline
Community Guest
Default Re: How to Inspect Water Heater Tanks Course
One of my favorite courses. A lot of good information.
Anchor Bay Inspections
Florida Licensed Home Inspector HI8446
941-676-2375
Serving Sarasota, Bradenton, Longboat Key, Anna Marie Island
Holmes Beach, Palmetto, Venice, Port Charlotte and Punta Gorda
Home Inspection - Wind Mitigation - Four Point Inspections
Old 2/12/15, 12:40 PM
Jerry F. Harcek, PLS Jerry F. Harcek, PLS is offline
This is a Quick and Hot under sink water heater made by the Anaheim Manufacturing Company. It is electric, heats water up to 190 degrees, uses an in-line water filter, and dispenses via a tap on top of the sink.
This one was a fairly new install, and worked properly.
Old 2/15/15, 2:07 PM
Daren A. Jones Daren A. Jones is offline
InterNACHI Student
in taking this course, posting required picture.
This electric heater is installed in a multi-story condo building, heater is installed on concrete blocks, no drain to outside, TPR venting to floor, and though not part of the water heater inspection, the MPOE service line, which has a water meter installed does not have any shut off. No way to turn water off without shutting down entire building!
How to Inspect Water Heater Tanks Course-water-heater-jpg
Old 2/16/15, 3:25 PM
Mika P. Richey Mika P. Richey is offline
Hello fellow future home inspectors and home inspectors. As a student I am required to post a picture as part of course. Below is my picture and a short visual description.
I found the hot water to be fully functional. No signs of leakage. Exspantion tack was in place on cold water side,water pressure valve prior to tank and water shut off valve Prior to water pressure valve . Tpr was in place and diverted to floor in garage. Electric wireing installed properly with no signs of issues. Water heater was elevated on stand 18 inches above floor.
Thanks guy's, Pat Richey
How to Inspect Water Heater Tanks Course-image-jpg
Old 2/16/15, 3:30 PM
Jeffrey R. Jonas's Avatar
You guys need to use a "real" camera for inspecting, and not your cell phones.
Yes, it is obvious!
Good luck.
Jeffrey R. Jonas
Owatonna, Minnesota
Old 2/16/15, 4:10 PM
Kevin C. VanHeulen, 1290 Kevin C. VanHeulen, 1290 is offline
This TPR valve was in place for this electric water heater. The discharge pipe was connected properly and extended within 6 inches of the floor. The hot water heater was installed before codes required expansion tanks.
How to Inspect Water Heater Tanks Course-20150208_195752-jpg
Old 2/16/15, 4:16 PM
Coming from a West Michigan market I can say that in Tennessee (at least in the Nashville market) they have more expansion tanks. This can only be attributed to the fact that most of the homes I have been (training) inspecting in TN are newer. In Michigan I inspected older homes and the previous codes most likely did not include them.
I would recommend at time of replacement that clients should have one installed if not sooner.
Old 2/16/15, 4:59 PM
Moisture intrusion
Water heater: Water heater did not have any signs of moisture intrusion. Water shut off valve, exspantion tank, water pressure reducing valve and all connections to water heater showed no signs of leakage. Electrical looked to be installed properly with no signs of arching or safety concerns.
Enterior back door: hardwood flooring showed signs of water intrusion du to visual signs of cracks.
Ceilings: Den ceiling showed water stains present on right side of fireplace.
Dinning and kitchen ceilings both showed signs of touch up painting showing possible water intrusion at some time or another.
I can only get one picture to post.Sorry!
Old 2/16/15, 8:36 PM
I am responding to the share your thoughts.
I chose the the water heater charts. I did have problems before I read this and this was just what I needed. This chart spells it out for you and a light bulb went off and now I get it. Thanks InterNACHI.
Old 2/18/15, 1:13 AM
Chester Bussell, TREC 187 Chester Bussell, TREC 187 is offline
InterNACHI Applicant
Fabulous video. I have been inspection for over 40 years and this is, without a doubt, the most informative information I have ever had on water heater inspections. I have never seen one cut open with the insides exposed.
Old 2/18/15, 4:39 PM
William (Greg) Floyd, TN 453 William (Greg) Floyd, TN 453 is offline
This water heater has seen better days. Along with having a plastic drain valve, the rust indicates that this water heater is not long for this world.
Old 2/18/15, 4:42 PM
The course is very educational.
Old 2/18/15, 4:46 PM
This has been one of my favorite courses. It was very educational. I look forward to many more of them
Old 2/20/15, 1:15 PM
Heather A. Reimiller Heather A. Reimiller is offline
Hey, Ya'll here's my picture of the HWR.
How to Inspect Water Heater Tanks Course-img_2478-1-jpg
Dual Water Heaters - parallel or series gmelien Plumbing Inspections 25 9/27/17 11:51 AM
hydronic radiant floor heat on hot water tanks mnicholet Plumbing Inspections 7 4/14/10 6:48 PM
Hot Water Heater djohnson6 Plumbing Inspections 12 12/28/06 10:18 PM
